IF450-SF00
IF450-SF00
    LAIRD(莱尔德)
    450MHz Panel RF Antenna 410MHz ~ 520MHz 3dBi Connector, SMA Female Chassis Mount
IF450-SF00 数据手册
450 MHz MicroSphere Antenna IF450 a The widespread use of cellular phones and wireless network applications inside buildings has increased the need for antenna systems that can provide considerable gain over traditional dipole antennas. Laird's in-building wireless antennas are particularly applicable in environments where aesthetics and wide angle coverage are necessary for successful wireless deployment. Their surprisingly small size allow the antennas to be hidden almost anywhere, providing an invisible solution for most applications. s s • Surprisingly small size allows it to be hidden almost anywhere, • The UHF band antenna is a good solution for stealth in-building public safety systems. providing an invisible solution for many applications. • The field pattern is toroidal, providing omni-directional s coverage in any plane around the long axis of the antenna, and two lobes in any plane parallel to the long axis. s Azimuth Plane Cut perpendicular to the antenna, parallel to the connector/cable exit, perpendicular to the polarization Element Type Microstrip Frequency Range 410-520 MHz (UHF) Peak Gain 3 dBi Polarization Linear Impedance 50 ohms Maximum Input Power 10 watts VSWR 2:1 Typical across the band Dimensions (L x W x H) 13 x 14.7 x .25 cm Housing Acrylic Operating/Storage Temperature C MODEL # REFERENCE # CONNECTOR IF450-SF00 CAF94350 SMA Female Panel s • Includes nylon screws for mounting to ceiling tile or finished ceiling Elevation Plane Cut perpendicular to the antenna, parallel to the connector/cable exit, parallel to the polarization axis Omni Plane Cut in the plane of the antenna perpendicular to the connector/cable exit Americas: +1.847 839.6907  IAS‐AmericasEastSales@lairdtech.com  Europe: +44.1628.858941  IAS‐EUSales@lairdtech.com  Asia:  +86.21.5855.0827.127  IAS‐AsiaSales@lairdtech.com  www.lairdtech.com  ANT-DS-IF450 0615 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
IF450-SF00 价格&库存
很抱歉,暂时无法提供与“IF450-SF00”相匹配的价格&库存,您可以联系我们找货
