B132S
B132S
    LAIRD(莱尔德)
    ANT MOBILE COIL VHF 1/4W 21" STR
B132S 数据手册
Mobile Load Coil Antenna Spring B132S PREMIUM MOBILE LOAD COIL ANTENNAS ARE INDUSTRY STANDARD Laird's ongoing commitment to refinement in mechanical and electrical design has resulted in the most technically advanced mobile load coil antennas on the market. Exclusive features such as stainless steel whips, housings constructed with ABS material injected molded around a solid brass insert, and gold plated push pin contacts make Laird the obvious choice for quality and long lasting value for demanding mobile radio communications. FEATURES MARKETS • Easily removable rod allows the mount to stay water tight during car washes • Public safety • O-ring built into the base creates a weather-tight seal • Utility • ABS material is injection molded directly around the solid brass inserts for a virtually indestructible housing that will not leak or dissassemble • Transportation • Military mobile • All silver soldered joints provide an electrically and mechanically secure connection ANTENNA PATTERNS Elevation Pattern (Y, Z, or H-plane) Normalized to 2dBi Azimuth Pattern (X, Y, or E-plane) Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Mobile Load Coil Antenna Spring B132S SPECIFICATIONS MODEL AND ORDERING INFORMATION ELECTRICAL Frequency Range VSWR MODEL No Spring 132-525 MHz With Spring 132-525 MHz B132S < 2.1 Max BB132S Nominal Gain 2 dBi Maxmium Power 200 W Nominal Impedance 50 Ω Polarization Pattern Half-Power Beamwidth (Elevation° x Azimuth°) Coaxial Cable Length & Type (For Vertical Polarization) Noise Suppressor Diameter Weight Equivalent Flat Plate Area (Wind Resistance in Sq. Ft.) Mounting Information (Sold Separately) Noise Suppressor OVERALL HEIGHT TUNING 23” See Cutting Chart 23” See Cutting Chart 132-525 MHz, Base Loaded 1/4 Wave Broadband, Chrome Finish 132-525 MHz, Base Loaded 1/4 Wave Broadband, Black Finish B132S CUTTING CHART Vertical FREQUENCY Omnidirectional 132 MHz 110° x 360° None BlackHawk NS1535 1-35 VOLT, 15 Amp Noise Suppessor (Sold Separately) WHIP LENGTH FREQUENCY WHIP LENGTH FREQUENCY WHIP LENGTH 19⅜” 156 MHz 16” 220 MHz 10½” 134 MHz 19” 158 MHz 15⅝” 230 MHz 10⅛” 136 MHz 18½” 160 MHz 15⅝” 240 MHz 9¾” 138 MHz 18⅛” 162 MHz 15” 250 MHz 9¼” 140 MHz 17⅞” 164 MHz 14⅞” 406 MHz 5⅝” 142 MHz 17⅝” 166 MHz 14⅝” 425 MHz 4⅛” 144 MHz 17½” 168 MHz 14½” 450 MHz 3⅝” 146 MHz 17¼” 170 MHz 14⅜” 475 MHz 3⅛” 148 MHz 17” 172 MHz 14⅛” 500 MHz 3” 150 MHz 16⅞” 174 MHz 14” 525 MHz 3¾” 23” (Also, see cutting chart) 152 MHz 16½” 200 MHz 11½” 1.44” 154 MHz 16¼” 210 MHz 11” MECHANICAL Height DESCRIPTION < 0.5 lb 0.023 sq. ft. NMO Mountable BlackHawk NS1535 1-35 VOLT, 15 Amp Noise Suppessor (Sold Separately) ANT-DS-B132S 111014 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
B132S 价格&库存
很抱歉,暂时无法提供与“B132S”相匹配的价格&库存,您可以联系我们找货
