PC804N
PC804N
    LAIRD(莱尔德)
    ANTENNA 806-902MHZ 6DBD N FML
PC804N 数据手册
Laird Technologies - Item # PC804N, 800 MHz Models - ESMR, SMR, Cellular, GSM a... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > Vehicular Antennas & Telematics > Cellular Antennas > Dual Band & Special Applications Antennas > PCS/DCS and 2.4 GHz ISM band Yagi antennas > 800 MHz Models ESMR, SMR, Cellular, GSM and Conventional > Item # PC804N Item # PC804N, 800 MHz Models - ESMR, SMR, Cellular, GSM and Conventional For 800 MHz ESMR and SMR or conventional applications, choose 4 element PC804N, 6 element PC806N or ten element PC8010N. The Cushcraft PC804N, PC826N and PC8210N are also available in the 900 MHz GSM frequency band. larger image larger image Specifications Band GSM SMR ESMR Celluar Conventional Frequency 806 to 902 MHz Gain 6 dBD No. of Elements 4 Front to Back Ratio 15 dB 3dB Beamwidth, E Plane 70 º 3dB Beamwidth, H Plane 90 º RF Connector N (Female) Wind Surface Area 0.11 m2 0.010 ft2 http://lairdtech.thomasnet.com/printitem/cpe-antennas-wimax-3g-4g-lte-cellular-bwa-/-mhz-... 8/8/2012 Laird Technologies - Item # PC804N, 800 MHz Models - ESMR, SMR, Cellular, GSM a... Wind Survival 125 mph 200 kph W/ 1/2" Ice 100 mph 161 kph Length 13 in 33 cm Weight 1.12 lbs 0.50 kg Power 200 watts Element Material 1/4 in (0.63 cm) 6061T6 Aluminum Rod Boom Material 3/4 in (1.9 cm) 6061T6 Aluminum Channel Mounting Style U Bolt Max. Mast Diameter 2 1/8 in 5.4 cm Pigtail 19 in 48.3 cm Page 2 of 2 http://lairdtech.thomasnet.com/printitem/cpe-antennas-wimax-3g-4g-lte-cellular-bwa-/-mhz-... 8/8/2012
PC804N 价格&库存
很抱歉,暂时无法提供与“PC804N”相匹配的价格&库存,您可以联系我们找货
