TW1320/TW1322 Embedded GPS/GLONASS Antenna
The TW1320/TW1322 is a high performance OEM GNSS
antenna covering the GPS L1, GLONASS L1 and SBAS
(WAAS, EGNOS & MSAS) frequency band (1575 to 1606
MHz). It features a patch element with 40% wider
bandwidth than previously available in this format.
Unlike its competitors, both GPS-L1 and GLONASS
signals are included in the 1dB RHCP received power
bandwidth.
The TW1320/TW1322 has a two stage Low Noise
Amplifier (LNA) with a mid-section SAW. An optional
tight pre-filter is available with part number TW1322 to
protect against saturation by high level sub-harmonics
and L-Band signals.
TW1320 Dimensions (mm)
The built-in 35mm circular ground plane should ideally
be augmented with a local system ground plane or
reflecting surface (DC connection not required).
OEM antennas are easily detuned by the local
environment. Tallysman offers custom tuning services
for optimized integration into OEM end-user modules.
Applications
Embedded OEM applications
Precision Agriculture, Mining & Construction
Military & Security
Avionics
Law Enforcement & Public Safety
Fleet Management & Asset Tracking
Features
Benefits
1dB bandwidth 1575MHz-1606MHz
Very low noise LNA: 1 dB
4dB Axial Ratio @1590MHz, 8db over B/W
High rejection SAW filter
LNA gain: 28dB TW1320, 26dB TW1322 typ.
Lowest current draw on the market -9mA
typical
ESD circuit protection: 15 KV
Wide Supply voltage: fixed 2.5V to 16V
Great multipath rejection
Increase system accuracy
Excellent signal to noise ratio
Great out of band signal rejection
Compact form factor
RoHS compliant
Specifications
At; Vcc = 3V, over full bandwidth, T=25°C
Antenna
Architecture
Polarization
1 dB Bandwidth
10dB Return Loss Bandwidth
Antenna Gain (with 100mm ground plane)
Axial Ratio
Wideband Single Feed Patch
RHCP
31MHz
45Hz
4.5dBic
SAW filter-> LNA stage 2
SAW Prefilter ->LNA stage 1 -> SAW filter-> LNA stage 2
1574MHz to 1606MHz
28dB min., TW1320; 26dB min, TW1322,
+/- 2dB, 1575MHz to 1606MHz
TW1320: 35dB. TW1322:
>70dB.
TW1320: 25dB. TW1322:
>45dB.
TW1320: >1650MHz
>35dB. TW1322:
>70dB.
