4G/3G Multiband
Phantom® Antenna
TRA6927M3
4G/3G Phantom® Antenna Ideal for
700/806/850/1800/1900/2100/2300/2500/2600 MHz Applications
The Laird Phantom antenna operates simultaneously in the 698-960 MHz and 1700-2700 MHz
bands, making it ideal for 4G/3G applications. The mechanically robust design is suitable for both
indoor and outdoor applications with wide bandwidth and a low angle radiation pattern that is
superior to traditional gain antennas in most applications. The antenna is ideal for both ceiling
and surface mount applications.
The industry standard NMO mounting socket mates with all Laird magnetic, trunk lid and hole
mount configurations. A threaded permanent stud mount model is also available for vandal
resistant mounting on brackets, panels, ceilings or any other kind of housing.
Features
Markets
• Mechanically robust for both
Indoor/Outdoor applications
• Public Safety
• Data transport
• Cellular
• Transportation
• Applicable for both 3G and
4G application
• M2M
• IBW
• Utilities
• Domestic LTE 700 band and
Global LTE 2600 band
• WiMAX 2300/2500/2600 bands
• Domestic Cellular and Global GSM
• Phantom out-performs a 3 dBi whip
in many applications
Antenna Patterns
Azimuth
Elevation
Azimuth
750 MHz
Azimuth
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Azimuth
849 MHz
Elevation
1710 MHz
Elevation
Azimuth
960 MHz
Elevation
1950 MHz
Elevation
Azimuth
Elevation
2700 MHz
4G/3G Multiband
Phantom® Antenna
TRA6927M3
SPECIFICATIONS
ELECTRICAL
Frequency Range
698-960 MHz, 1710-2700 MHz
VSWR
698-806 MHz
< 2.5: 1.0
806-960 MHz
< 2.0: 1.0
1710-2110 MHz
< 2.0: 1.0
2110- 2170 MHz
< 2.5: 1.0
2300- 2700 MHz
< 2.0: 1.0
Nominal Peak Gain
698-960 MHz
3.5 dBi
1710-1990 MHz
5.5 dBi
2100-2700 MHz
4.6 dBi
Average Efficiency
698-960 MHz
90% (max: 96%)
1710-1990 MHz
91% (max: 95%)
2100-2700 MHz
80% (max: 86%)
Polarization
Vertical
Pattern
Omnidirectional
Input Impedance
50 Ω
Maximum Power
100 W
Cable & Mount
MB195 (Sold Separately)
Terminations
NMO or P-Mount w/Type N(f)
Mechanical
Color
Black or white available
Radome Material
High Heat ABS
Dimensions (Ht. x dia.)
3.3” (8.38 cm) x 1.44” (3.65 cm)
Operating Temperature
-40° C to 85°C
MODEL AND ORDERING INFORMATION
MODEL
DESCRIPTION
COLOR
RADOME HEIGHT
WEIGHT CONNECTOR
TRA6927M3PB-001
4G/3G Phantom®
Black
3.30”
0.38 lbs Type N(f)
TRA6927M3NB-001
4G/3G Phantom®
Black
3.30”
0.28 lbs NMO
TRA6927M3PW-001
4G/3G Phantom
White
3.30”
0.38 lbs Type N(f)
TRA6927M3NW-001
4G/3G Phantom®
White
3.30”
0.28 lbs NMO
Permanent Mounting Option:
The letter “P” in the above part numbers indicates
a permanent mounting option
ANT-DS-TRA6927M3 0515
Any information furnished by Laird, Inc and their agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or
products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold
pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved.
Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or
service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“TRA6927M3NB-001”相匹配的价格&库存,您可以联系我们找货
