TRA8903N
TRA8903N
    LAIRD(莱尔德)
    OMNIPHNMO890-960MHZ
TRA8903N 数据手册
Phantom® 800 MHz-5.8GHz Antennas Phantom® antenna is ideal for Cell, GSM, PCE, WiFi, 802.11 and Bluetooth wireless applications Laird's unique patented Phantom® is a tough low-profile antenna for outdoor or indoor applications. Measuring only 2.7” tall, the Phantom 800 MHz to 5.8 GHz antenna models’ revolutionary design features field diversity with both vertical and horizontal polarization components. This gives the antenna diversity, frequency agility, low visibility, wide bandwidth and a low angle radiation pattern that is superior to traditional gain antennas in most applications. The industry standard NMO mounting socket mates with all Laird Technolgies’ magnetic, trunk lid, and hole mounts. A threaded permanent stud mount model is also available for vandal resistant mounting on brackets, panels, ceilings or any other kind of housing. The Phantom® patented technology is beneficial when high performance is desired and extreme ruggedness and low profile is required. Features Markets • True Field Diversity design ensures uninterrupted transmissions in urban canyons and rural drop off areas • Cell • GSM and PCS • WiFi • Phantom® outperforms a 3dB whip in many applications • 802.11 • Bluetooth wireless applications • U.S. Patent Nos. 5,977,931 – 6,292,156 and 7,209,096 ° 10° ° 350 340 30 0° 33 32 0° 40 ° 30 ° 10° 350° ° 340 20° 40 ° 0° 32 20° 70° -20 80° 90 ° 100° 110° 12 0° 13 0° 0° 23 90° 0° 160 ° 180° 170° 30 0° 290 ° 280° 270° ° ° 190° 200 0° 15 21 0° 14 22 0° Azimuth Pattern (X,Y, or E-plane) Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com www.lairdtech.com ° -30 -40 -50 250 80° 60 260° 70° ° 50 0° 24 ° 60 27 0° 31 0° Elevation Pattern (Y, Z, or H-plane) -4 -6 -8 -10 280° -30 -40 -50 ° ° -20 50 290 -4 -6 -8 -10 0 -2 30 0° 0 -2 31 0° 0° 33 Antenna Patterns Phantom® 800 MHz-5.8GHz Antennas SPECIFICATIONS MODEL AND ORDERING INFORMATION ELECTRICAL MODEL DESCRIPTION < 2.1 TRA8063 806-870 MHz 3 dB-MEG Phantom® ¾ NMO, White Radome 3 dB-M.E.G. TRA8213 821-896 MHz 3 dB-MEG Phantom® ¾ NMO, White Radome Maximum Power 100 W TRA8903 890-960 MHz 3 dB-MEG Phantom® ¾ NMO, White Radome Nominal Impedance 50 Ω TRA9023 902-928 MHz 3 dB-MEG Phantom® ¾ NMO, White Radome TRA18503 1.85 - 1.99 GHz 3dB-MEG Phantom® ¾ NMO, White Radome TRA24003 2.4 – 2.5 GHz 3 dB-MEG Phantom® ¾ NMO, White Radome TRA58003 4.9 – 6.0 GHz 3 dB-MEG Phantom® ¾ NMO, White Radome VSWR Nominal Gain Polarization Pattern Half-Power Beamwidth (Elevation° x Azimuth°) Coaxial Cable Length & Type Terminations Vertical Omnidirectional 130° x 360° None NMO Socket or, type N-female Height (initially) Black or White 2¾” Diameter 1.438” Weight 0.173 lb Material Mounting Information Noise Suppressor Sealtube3 G - Drop ceiling antenna adaptor for P-mount Phantom w/ 6”x6”x0.016” ground plane Heat shrink tubing 3”x1”DIA install (use for jaw protector on installation wrench) Add “B” to model number for black radome. Example: TRAB8063 Add “P” to model number for Permanent Mount. Example: TRA8063P Mechanical Color TRADCAGP ABS NMO (PN: MB8, MAB8) Sold Separately BlackHawk NS1535 1-35 VOLT, 15 Amp Noise Suppessor (Sold Separately) Permanent Mounting Option: Please order by antenna model and insert letter “P” to indicate permanent mounting option (TRA8063P). ANT-DS-PHANTOM 800-5800 MHz 1214 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
TRA8903N 价格&库存
很抱歉,暂时无法提供与“TRA8903N”相匹配的价格&库存,您可以联系我们找货
