TRA8063M3NW-001
TRA8063M3NW-001
    LAIRD(莱尔德)
    OMNIPHNMO80618502.5
TRA8063M3NW-001 数据手册
Phantom® Tri-band Antenna TRA8063M3 TRI-BAND PHANTOM® ANTENNA IDEAL FOR 806/850/1900/2600 MHZ APPLICATIONS Lairds’ unique Phantom® antenna operates simultaneously in the 806-896 MHz, 1850-1990 MHz and 2500-2700 MHz bands. The mechanically robust design is suitable for both indoor and outdoor applications. With wide bandwidth and a low angle radiation pattern that is superior to traditional gain antennas in most applications, the antenna can be used in both ceiling mount and surface mount applications. The industry standard NMO mounting socket mates with all Lairds’ magnetic, trunk lid and hole mount configurations. A threaded permanent stud mount model is also available for vandal resistant mounting on brackets, panels, ceilings or any other kind of housing. FEATURES MARKETS • Mechanically robust for both Indoor/Outdoor applications • Public Safety • Utility • Cellular • Transportation • Suitable for high band 4G application • M2M • IBW • Phantom antenna outperforms a 3 dBi whip in many applications ANTENNA PATTERNS Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Phantom® Tri-Band Antenna TRA8063M3 SPECIFICATIONS ELECTRICAL Frequency Range 806-896 MHz, 1850-1990 MHz, 2500-2700 MHz VSWR < 2.1: 1.0 Return Loss -10dB max Nominal Peak Gain 806-896 MHz 4 dBi 1850-1990 MHz 3.5 dBi 2500-2700 MHz 3.0 dBi Average Efficiency 806-896 MHz 89% (max: 93%) 1850-1990 MHz 73% (max: 74%) 2500-2700 MHz 77% (max: 82%) Polarization Pattern Vertical Omnidirectional Input Impedance 50 Ω Maximum Power 100 W Cable & Mount MB195 (Sold Separately) Terminations NMO or P Mount w/N Female Connector MECHANICAL Color Radome Material Black or white available High Heat ABS Dimensions (Ht. x dia.) 3.3” (8.38 cm) x 1.44” (3.65 cm) Operating Temperature -40° C to 85°C MODEL AND ORDERING INFORMATION COLOR RADOME HEIGHT WEIGHT CONNECTOR TRA8063M3PB-001 ® Tri Band Phantom Black 3.30” 0.38 lbs Type N(f) TRA8063M3NB-001 Tri Band Phantom® Black 3.30” 0.28 lbs NMO TRA8063M3PW-001 ® Tri Band Phantom White 3.30” 0.38 lbs Type N(f) TRA8063M3NW-001 Tri Band Phantom® White 3.30” 0.28 lbs NMO MODEL DESCRIPTION Permanent Mounting Option: The letter “P” in the above part numbers indicates a permanent mounting option ANT-DS-TRA8063M3 1214 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
TRA8063M3NW-001 价格&库存
很抱歉,暂时无法提供与“TRA8063M3NW-001”相匹配的价格&库存,您可以联系我们找货
