TW4027/TW4029 Low Current GPS Antenna
The TW4027/TW4029 is a very low power,
compact GNSS antenna covering the GPS L1,
frequency band. This antenna features an LNA
with a nominal current consumption of just
2mA, with constant performance from 2.5V to
15V supply voltage, and includes protection
against close proximity L-band transmitting
antennas such as Iridium™ and Globalstar™
The TW4027/TW4029 has among the lowest
power consumption available, yet still provides
21dB nominal gain and an excellent Noise
Figure. The TW4027.TW4029 patch has 40%
wider bandwidth for better axial ratio and has
15 KV ESD circuit protection. The LNA has a
+/- 10MHz bandwidth that covers the full GPS
L1 signal plus the SBAS (WAAS /EGNOS/MSAS)
frequency band (1572.5 to 1578 MHz).
The TW4029 variant provides a “Brick-Wall”
pre-filter to protect against saturation by high
level sub-harmonics and L-Band signals.
It is housed in a compact IP67 magnetic mount
enclosure.
Applications
Battery operated monitoring
Covert Surveillance
Fleet Management & Asset Tracking
Satcom based AVL solutions
Features
Benefits
Nominal 2mA current draw
Invariant response, 2.5 to 16 VDC Supply
Low Noise 1.0dB/3.5dB Typ. (TW4027/TW4029)
Axial ratio: 4 dB max (GPS )
TW4122 “Brick-Wall pre-filter option
High gain: 24dB/18dB Typ. (TW4027/TW4029)
IP67 weather proof housing
Longer battery life
Excellent signal to noise ratio
RoHS compliant
Ideal for harsh environments
Excellent out of band signal rejection
TW4027/TW4029 Low Power GPS Antenna
Specifications Vcc = 3V, over full bandwidth, T=25°C
Antenna
Architecture
1 dB Bandwidth
10dB Return Loss Bandwidth
Antenna Gain (with 100mm ground plane)
Axial Ratio over Bandwidth
Polarization
Electrical
Architecture
Gain @ 1575.42 MHz
Gain flatness
Out-of-Band Rejection
LNA1->SAW -> LNA2
TW4029: Patch -> Pre-filter SAW-> LNA1> SAW -> LNA2,
24dB Typ, 21dB Min (TW4027); , 21dB Typ,18dB Min (TW4029)
+/- 2 dB
>32 dB (TW4027)
>50dB (TW4029)
>25 dB
>50dB
>35 dB
>70dB
很抱歉,暂时无法提供与“32-4027-13-1200”相匹配的价格&库存,您可以联系我们找货
