33-4421-05-5000
33-4421-05-5000
    TALLYSMANWIRELESS
33-4421-05-5000 数据手册
A Tallysman Accutenna® TW4421/TW4422 Wideband Dual Feed GPS/GLONASS Antenna The TW4421/TW4422 employs Tallysman’s patented Accutenna® technology covering the GPS L1, GLONASS G1, and SBAS (WAAS, EGNOS & MSAS) frequency band (1574 to 1606 MHz). The TW4421/TW4422 features a novel 25mm dual feed wideband patch element that provides a more linear carrier phase response by virtue of the axial ratio that is greatly improved across the full frequency bandwidth. It provides truly circular response over its entire bandwidth thereby producing superior multipath signal rejection. It is especially suitable for high accuracy applications while providing high out of band signal rejection. The two feeds from the patch element are summed in a 90° Hybrid then input to a first stage Low Noise Amplifier (LNA), followed by a mid-section SAW and a second low noise gain stage. The TW4422 has a pre-filter which increases the antenna’s immunity to high amplitude interfering signals, such as LTE and other cellular signals The TW4421/TW4422 is the smallest dual feed, high performance antenna available. It is housed in a compact IP67 magnetic or adhesive mount enclosure. It is available with a wide range of cable and connector options. The antenna can be ordered without the magnet. In such cases, the magnet is replaced with a plastic plug to provide a smooth under surface, with the option of ordering it with or without 1.1 mm doublesided VHB tape on the bottom. Applications • • • • Cost Sensitive Mission Critical Positioning Military & Security Covert surveillance Fleet Management & Asset Tracking Features • • • • • • • • Dual feed patch element Axial ratio: 2.5 dB Max. (GPS & GLONASS) Low noise LNA: 1 dB High rejection mid-section SAW filter High gain: 26 dB typ. Wide voltage input range: 2.5 to 16 VDC IP67 weather proof housing Low Power: 9mA typ. at 2.3Vcc min. Benefits • • • • • • • 1dB Bandwidth Includes GPS-L1 & GLONASS Greatly enhanced multipath rejection Improved GNSS reliability Excellent signal to noise ratio RoHS compliant Ideal for harsh environments Excellent out of band signal rejection TW4421/TW4422 Wideband Dual Feed GPS/GLONASS Antenna Specifications At; Vcc = 3V, over full bandwidth, T=25°C Antenna Architecture 1 dB radiated power bandwidth (RHCP) Antenna Gain (with 100mm ground plane) Axial Ratio over full bandwidth, Polarization Electrical Architecture Filtered LNA Frequency Bandwidth Gain Gain flatness Out-of-Band Rejection VSWR (at LNA output) Noise Figure Supply Voltage Range (over coaxial cable) Supply Current ESD Circuit Protection Mechanicals & Environmental Mechanical Size Cable Operating Temp. Range Enclosure Weight Attachment Method Environmental Shock Vibration Warranty Wideband Dual Feed Patch Element 32 MHz 4.5 dBic Hybrid->LNA stage 1 -> SAW filter-> LNA stage 2 1575 to 1606 MHz TW4421: 26dB -2/+1, TW4422: 26dB -2/+1 +/- 2dB, 1575 MHz to 1606MHz TW4421 TW4422 32dB >60dB 25dB >55dB >1640MHz: >60dB >65dB
33-4421-05-5000 价格&库存
很抱歉,暂时无法提供与“33-4421-05-5000”相匹配的价格&库存,您可以联系我们找货
