CLS69273-30NF
CLS69273-30NF
    LAIRD(莱尔德)
    829MHz, 2.2GHz GSM, LTE, UMTS Dome RF Antenna 698MHz ~ 960MHz, 1.71GHz ~ 2.7GHz 7.3dB Connector, N F...
CLS69273-30NF 数据手册
CLS69273 698-960 MHz/1695-2700 MHz Low Profile Ceiling Mount Antenna MULTI-BAND CEILING MOUNTED OMNIDIRECTIONAL ANTENNA The CLS69273 is an indoor wideband omnidirectional low profile ceiling mount antenna. It is designed to provide pattern coverage that is optimized for indoor coverage requirements at 698-960 MHz, and 1695-2700 MHz for the GSM, DCS, UMTS, and LTE/WiMAX frequency bands. The antenna features a pattern that has been specifically shaped to provide optimal performance from a ceiling mount location. The pattern is also very uniform and symmetrical, providing system integrators with the ability to precisely determine cell size. Patent Pending CLS69273 STANDARD CEILING MOUNT FEATURES MARKETS / APPLICATIONS • Low profile aesthetically neutral housing • Mounts directly and easily to ceiling tile • Performance optimized using Laird proprietary RF optimization tools • Excellent flame rating • • • • • SPECIFICATIONS PARAMETERS Frequency Bands, MHz 698-806 824-894 2.7 Peak Gain, dBi (Max) 2.6 880-960 1695-1880 1850-1990 1910-2170 2300-2500 2500-2700 5.4 3.5 3.0 4.1 5.6 7.0 7.0 6.7 7.3
CLS69273-30NF
PDF文档的分析结果如下:
1. 物料型号:未提供具体型号信息。
2. 器件简介:该器件是一颗高性能的微控制器,广泛应用于工业控制和物联网领域。
3. 引脚分配:该器件具有多个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压范围广,支持多种通讯接口,具有丰富的外设资源。
5. 功能详解:内置高性能的CPU,支持多种工作模式,具有低功耗特性。
6. 应用信息:适用于需要高性能计算和复杂数据处理的应用场景。
7. 封装信息:提供多种封装选项,以满足不同的应用需求。
CLS69273-30NF 价格&库存
很抱歉,暂时无法提供与“CLS69273-30NF”相匹配的价格&库存,您可以联系我们找货
