ANT-2.4-OM-CM-01-N
ANT-2.4-OM-CM-01-N
    LINXTECHNOLOGIES(灵思)
    ANT-2.4-OM-CM-01-N
ANT-2.4-OM-CM-01-N 数据手册
™ ANT-2.4-OM-CM-01-N DATA SHEET Product Dimensions Description The OM Series of gain antennas are designed to increase the range and reliability of wireless links while maintaining an omnidirectional pattern around the circumference of the antenna. This characteristic allows for greater flexibility in the placement of system devices than is often found in typical gain antenna soulutions. OM Series antennas also feature rugged, weatherized construction making them well suited for both indoor and outdoor applications. The antenna includes complete mounting hardware for standard masts. The standard antenna features 7dBi gain. Higher gain versions are avaliable upon request. ø1.35” (34.3) ø1.24” (31.5) *NOTE* Use of these antennas may result in TX and RX emission levels in excess of legal limits. Features 25.1” (637) 3.22” (81.8) 1.63” (41.4) • • • • • 24.3” (617) High gain Fiberglass radome construction Fully weatherized Rugged & damage-resistant N connector Electrical Specifications 0.94” (23.8) 0.78” (19.8) BASE DETAIL • • • • • • • • • • • • Center Freq. Bandwidth Polarization VSWR Impedance Gain Beamwidth Max. Power Connector Mounting Weight Wind Velocity 2.45GHz 83MHz (2400 - 2483) Vertical ≤1.5 typ. at center 50 ohms 7dBi 360º horizontal, 13º vertical 20W N-style female 2-pc bracket with U-bolts, 1.58”-1.97”(40-50mm) mast 3.3lbs (1.5kg) 124mph (56m/s) Ordering Information • ANT-2.4-OM-CM-01-N Visit connectorcity.com for cable assemblies VSWR Graph N Style Connector S11 SWR 1.107 Mounting Hardware (Included) CENTER 2450.000MHz SPAN 200.000MHz Typical VSWR Antenna Factor 159 Ort Lane Merlin, OR 97532 www.antennafactor.com 541-956-0931 (phone) 541-471-6251 (fax) Rev 4-9-10
ANT-2.4-OM-CM-01-N 价格&库存
很抱歉,暂时无法提供与“ANT-2.4-OM-CM-01-N”相匹配的价格&库存,您可以联系我们找货
ANT-2.4-OM-CM-01-N
    • 1+732.27240
    • 200+292.18320
    • 500+282.42000
    • 1000+277.59240
