Phantom® Tri-band Antenna
TRA8063M3
TRI-BAND PHANTOM® ANTENNA IDEAL FOR
806/850/1900/2600 MHZ APPLICATIONS
Lairds’ unique Phantom® antenna operates simultaneously in the 806-896 MHz, 1850-1990
MHz and 2500-2700 MHz bands. The mechanically robust design is suitable for both indoor
and outdoor applications. With wide bandwidth and a low angle radiation pattern that is
superior to traditional gain antennas in most applications, the antenna can be used in both
ceiling mount and surface mount applications.
The industry standard NMO mounting socket mates with all Lairds’ magnetic, trunk lid and
hole mount configurations. A threaded permanent stud mount model is also available for
vandal resistant mounting on brackets, panels, ceilings or any other kind
of housing.
FEATURES
MARKETS
• Mechanically robust for both
Indoor/Outdoor applications
• Public Safety
• Utility
• Cellular
• Transportation
• Suitable for high band 4G application
• M2M
• IBW
• Phantom antenna outperforms a 3 dBi
whip in many applications
ANTENNA PATTERNS
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Phantom® Tri-Band Antenna
TRA8063M3
SPECIFICATIONS
ELECTRICAL
Frequency Range
806-896 MHz, 1850-1990 MHz, 2500-2700 MHz
VSWR
< 2.1: 1.0
Return Loss
-10dB max
Nominal Peak Gain
806-896 MHz
4 dBi
1850-1990 MHz
3.5 dBi
2500-2700 MHz
3.0 dBi
Average Efficiency
806-896 MHz
89% (max: 93%)
1850-1990 MHz
73% (max: 74%)
2500-2700 MHz
77% (max: 82%)
Polarization
Pattern
Vertical
Omnidirectional
Input Impedance
50 Ω
Maximum Power
100 W
Cable & Mount
MB195 (Sold Separately)
Terminations
NMO or P Mount w/N Female Connector
MECHANICAL
Color
Radome Material
Black or white available
High Heat ABS
Dimensions (Ht. x dia.)
3.3” (8.38 cm) x 1.44” (3.65 cm)
Operating Temperature
-40° C to 85°C
MODEL AND ORDERING INFORMATION
COLOR
RADOME
HEIGHT
WEIGHT CONNECTOR
TRA8063M3PB-001
Tri Band Phantom
Black
3.30”
0.38 lbs Type N(f)
TRA8063M3NB-001
Tri Band Phantom®
Black
3.30”
0.28 lbs NMO
TRA8063M3PW-001
Tri Band Phantom
White
3.30”
0.38 lbs Type N(f)
TRA8063M3NW-001
Tri Band Phantom®
White
3.30”
0.28 lbs NMO
MODEL
DESCRIPTION
Permanent Mounting Option:
The letter “P” in the above part numbers indicates
a permanent mounting option
ANT-DS-TRA8063M3 1214
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or
products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and
Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird
Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“TRA8063M3PW-001”相匹配的价格&库存,您可以联系我们找货
