WM.80.B.305111
WM.80.B.305111
    TAOGLASLIMITED
    WM.80.B.305111
WM.80.B.305111 数据手册
Specification Part No. : WM.80.B.305111 Product Name : 169MHz 0dBi Wall Mount Flexible Whip Monopole Omni-Directional Antenna SMA Male connector Feature : ¼ Wavelength Flexible Inner Steel Core Whip IP65, Robust Structure, Aesthetic 3m CFD-200 SMA(M)ST Cable is hidden internally CE Certified RoHS & REACH Compliant SPE-13-8-061/B/MWC Page 1 of 6 1. Introduction The WM.80 is a 0dBi 169MHz ISM band 1/4 wavelength monopole flexible whip antenna with omni- directional pattern optimized in the azimuth for wide coverage range in typical 169MHz applications such as Wireless M-Bus metering. It also finds its usage in remote asset monitoring applications, alarms, paging systems and private mobile radio services. This antenna delivers wider coverage areas and more reliable connections for professional customers in the automotive, industrial industries. The whip is made up of a flexible inner steel core covered by TPU so extremely resistant to collisions and maintaining its original shape and RF performance. The bracket allows complete concealment of the cable for a more secure integration and cleaner installation. The cable can also be routed out of the back wall of the bracket into the interior of the mounting wall for added security against vandalism. The standard version comes with 3 meters extremely low loss CFD-200 cable (0.3dB against 0.7dB for RG58) to allow for flexibility of placement. The cable and connector can be completely customized, the whip itself can also be changed for different frequency bands or gain requirements. For further information please contact your regional Taoglas customer support team. SPE-13-8-061/B/MWC Page 2 of 6 2. Specification CELLULAR ELECTRICAL Frequency (MHz) 169 Peak Gain (dBi) * 0dBi Average Gain (dBi) * -3.9 Efficiency (%) * 40% Impedance (Ω) 50 Polarization Linear Radiation Pattern Omni Input Power(W) 50 Tested Power(W) 10 MECHANICAL Bracket Dimensions (mm) 120*118*32mm Base Diameter (mm) φ16 Whip Diameter (mm) φ4 Casing ABS Connector SMA(M) ENVIRONMENTAL Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH * For low frequency antennas these parameters can only be estimated using RF formula calculation, simulation or rough field test comparisons with large benchmark antennas. SPE-13-8-061/B/MWC Page 3 of 6 3. Antenna Characteristics 3.1 Antenna setup in free space in free space, through reference board SPE-13-8-061/B/MWC Page 4 of 6 3.2 Return loss SPE-13-8-061/B/MWC Page 5 of 6 4. Antenna Drawing SPE-13-8-061/B/MWC © Taoglas Page 6 of 6
WM.80.B.305111 价格&库存
很抱歉,暂时无法提供与“WM.80.B.305111”相匹配的价格&库存,您可以联系我们找货
WM.80.B.305111
    • 1+1026.22680
    • 200+409.47120
    • 500+395.78760
    • 1000+389.02680
