TRA4903P
TRA4903P
    LAIRD(莱尔德)
    OMNI PH 490-512MHZ 3DBI 150W WHT
TRA4903P 数据手册
Phantom® UHF Antennas PHANTOM® UHF ANTENNA OUTPERFORMS CONVENTIONAL MOBILE ANTENNAS IN MANY APPLICATIONS Laird's unique patented Phantom® is a tough antenna for outdoor or indoor applications. Measuring only 3.4” tall, the Phantom UHF antenna’s revolutionary design features vertical polarization components. The Phantom®provides low visibility, wide bandwidth and a low angle radiation pattern that is superior to traditional gain antennas in most applications. The industry standard NMO mounting socket mates with all Laird magnetic, trunk lid, and hole mounts. A threaded permanent stud mount model is also available for vandal resistant mounting on brackets, panels, ceilings or any other kind of housing. The Phantom® patented technology is beneficial when high performance is desired and extreme ruggedness and low profile is required. FEATURES MARKETS • Phantom outperforms a 3dB whip in many applications • Public safety • U.S. Patent Nos. 5,977,931 – 6,292,156 and 7,209,096 • Utility ® • Transportation • Military mobile • Fixed radio applications SPECIFICATIONS ELECTRICAL VSWR (Measured on 2’ x 2’ GP) Peak Gain 3 dBi Maximum Power 100 W Nominal Impedance Polarization Pattern Half-Power Beamwidth (Elevation° x Azimuth°) Coaxial Cable Length & Type Terminations Noise Suppressor Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com < 1.5:1 @ 10 MHz < 2.0:1 @ 20 MHz 50 Ω Vertical Omnidirectional 146° x 360° None NMO BlackHawk NS1535 1-35 VOLT, 15 Amp Noise Suppessor (Sold Separately) Phantom® UHF Antennas SPECIFICATIONS FORM FACTOR DRAWING MECHANICAL 3½” * Height (initially) Diameter 1.438” Weight 0.21 lbs. Rated Wind Velocity 125mph (210 kph) Rated Wind Velocity (with 0.5” radial ice) 85mph (137 kph) Lateral Thrust @ 125mph Wind Velocity 57 lbs. (26kg) Wind Resistance in Sq. Feet 0.0356 Sq. ft. Material ABS Mounting Information NMO or Permanent Mountable * Add .835” for Permanent Mount option Permanent Mounting Option: Please order by antenna model and insert letter “P” to indicate permanent mounting option (TRA4503P). MODEL AND ORDERING INFORMATION MODEL DESCRIPTION TRA3003 300-305 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB3003 300-305 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA3803 380-400 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB3803 380-400 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4063 406-425 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4063 406-425 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4103 410-430 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4103 410-430 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4303 430-450 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4303 430-450 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4503 450-470 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4503 450-470 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4703 470-490 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4703 470-490 MHz 3 dBi Phantom® ¾ NMO, Black Radome TRA4903 490-512 MHz 3 dBi Phantom® ¾ NMO, White Radome TRAB4903 490-512 MHz 3 dBi Phantom® ¾ NMO, Black Radome Sealtube3 Heat shrink tubing 3”x1”DIA Elite install (use for jaw protector on installation wrench) ANT-DS-PHANTOM UHF 0615 Any information furnished by Laird, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
TRA4903P 价格&库存
很抱歉,暂时无法提供与“TRA4903P”相匹配的价格&库存,您可以联系我们找货
