Phantom® Antennas
TRA(B)24/49003(P)
Dual-Band Phantom® antenna is ideal for Wlan and 4.9 Ghz
public safety applications
Laird Technologies’ unique patented Phantom® dual-band antenna operates
simultaneously at 2.4 GHz and 4.9 GHz and is a tough antenna for outdoor or indoor
applications. The revolutionary design measures only 2.3” and features both vertical and
horizontal polarization. This gives the antenna diversity, frequency agility, low visibility,
wide bandwidth and a low angle radiation pattern that is superior to traditional gain
antennas in most applications. The industry standard NMO mounting socket mates with
all Laird Technologies’ magnetic, trunk lid, and hole mounts. A threaded permanent stud
mount model is also available for vandal resistant mounting on brackets, panels, ceilings
or any other kind of housing.
Features
Markets
• Cross-polarization design ensures
uninterrupted transmissions in urban
canyons and rural drop-off areas
• Public safety
• Phantom® outperforms a 3dB whip in
many applications
• U.S. Patent Nos. 5,977,931 – 6,292,156
and 7,209,096
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
• Transportation
• Utility
• Military mobile
• Fixed radio applications
Phantom® Antennas
TRA(B)24/49003(P)
SPECIFICATIONS
MODEL AND ORDERING INFORMATION
MODEL
ELECTRICAL
DESCRIPTION
ISM, 2.4-2.5 GHz / 4.9-5.85 GHz
TRA24/49003
NMO Mount, White Radome
2400 MHz
4900 MHz
TRAB24/49003
NMO Mount, Black Radome
TRA24/49003P
P-Mount, White Radome
Peak Gain (dBi)
Azimuth Cut, Phi=0°
0.7
0.9
TRAB24/49003P
P-Mount, Black Radome
Peak Gain (dBi)
Elevation Cut, Phi=90°
0.6
5.7
Elevation Beamwidth
at Half-Power
30°
65°
Azimuth Beamwidth
at Half-Power
130°
230°
Frequency Band
Frequency Range
(Test Frequency at Peak)
Max Gain: 0.7 dBi
Average Gain: -3.9 dBi
Max Angle: 325.0°
Mechanical
Antenna Dimensions
Weight (Mass)
1.44”(36.5 mm)dia x 2.3”(58.4 mm)H
0.25 lb (113.4 g)
TECHNICAL DATA
Pattern
Omni-Directional
Maximum Power
100W
Nominal Impedance
50 ohm
Polarization
VSWR
Termination
F/B Ratio
Vertical and Horizontal
很抱歉,暂时无法提供与“TRA24/49003P”相匹配的价格&库存,您可以联系我们找货
