GD24-15P-RTNC
GD24-15P-RTNC
    LAIRD(莱尔德)
    ANT GRID 15DBI 2.4GHZ 30" RTNC
GD24-15P-RTNC 数据手册
Grid Dish Parabolic Antenna GD24 2400 TO 2485 MHz GRID DISH PARABOLIC ANTENNA The 2.4 GHz parabolic grid directional antennas offered by Laird utilize a patented parabolic grid design with a patented high performance dipole feed. The antennas are constructed of welded steel wires which are galvanized and then powder coat painted with a light gray epoxy paint. The wire grid semi-parabolic design offers unsurpassed low wind loading while maintaining good RF performance. The compact low visual impact attractive styling blends well in almost any application. Mounting is simplified with the Laird bracket system made of galvanized steel with stainless steel hardware. A super heavy duty “HD” bracket system is available for the 24 dB grid. The antennas come with a 30 inch pigtail with choice of N male, N female or RPSMA connector. FEATURES MARKETS • • • • • • • • • • • 15 dBi, 19 dBi, and 24 dBi models available Rugged and weatherproof Ultra low wind loading and low visual impact Vertical or horizontal polarization Various connector choices Super HD bracket 2 dBi model available for greater stability 2.4 GHz wireless LAN applications Client antennas 802.11b/g applications Point-to-point backhaul WiMAX ANTENNA PATTERN GD24-15 2450.0 MHz Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com GD24-19 2450.0 MHz GD24-24 2450.0 MHz Grid Dish Parabolic Antenna GD24 SPECIFICATIONS PARAMETER GD24-15 GD24-19 GD24-24 2400-2485 MHz 2400-2485 MHz 2400-2485 MHz 15 dBi 19 dBi 24 dBi 17° vert., 21° hor. 11° vert., 17° hor. 8° vert., 10° hor. Front to back 17 dB 22 dB 25 dB VSWR 1.5:1 1.5:1 1.5:1 50 ohm 50 ohm 50 ohm Frequency range Gain 3dB beamwidth Impedance Input power Operating temperature Pole size 100 watts 100 watts 100 watts -40° to +70°C -40° to +70°C -40° to +70°C 1 to 2 in (25 to 50 mm) Weight 1 to 2 in (25 to 50 mm) 4 lbs (1.8 kg) Dimension (W x L) 6 lbs (2.7 kg) 12 x 16 in (305 x 406 mm) Bracket tilt 1 to 2 in (25 to 50 mm) 11 lbs (5 kg) 16.5 x 24 in (419 x 610 mm) 45° 28.5 x 36 in (724 x 914 mm) 45° 45° WIND LOADING (LBS.) MODEL SQ. IN 100 MPH 125 MPH 100 MPH WITH ½ IN RADIAL ICE GD24-15 40 10 lbs 15.6 lbs 48 lbs GD24-19 79 20 lbs 31 lbs 99 lbs GD24-24 163 41 lbs 64 lbs 257 lbs 15 19 24 NM (N male) NF (N female) RSMA (RPSMA) NOTES • All shipments F.O.B. Schaumburg, IL 60173 * Super HD Bracket System Now Available for 24 dBi Grid. Add “HD” as prefix to part number. Example: HDGD24-24P-NF Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-GD24 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
GD24-15P-RTNC 价格&库存
很抱歉,暂时无法提供与“GD24-15P-RTNC”相匹配的价格&库存,您可以联系我们找货
