GD53-21
GD53-21
    LAIRD(莱尔德)
    ANT GRID 21DBI 5.1-5.3GHZ N FEM
GD53-21 数据手册
Grid Dish Parabolic Antenna GD5x 5150 TO 5850 MHz GRID DISH PARABOLIC ANTENNA The 5 GHz parabolic grid directional antennas offered by Laird utilize a unique patented parabolic grid design with compact high performance feed. The antennas are constructed of welded steel wires which are galvanized and then powder coat painted with a light gray epoxy paint. The wire grid semi-parabolic design offers unsurpassed low wind loading while maintaining good RF performance. The compact low visual impact attractive styling blends well in almost any application. Mounting is simplified with the Laird bracket system made of galvanized steel with stainless steel hardware. The antenna comes with a bulkhead N female connector standard. FEATURES MARKETS • • • • • • • 5 GHz wireless LAN applications • Point-to-point backhaul • WiMAX 22 dBi , 26 dBi, and 29 dBi models available Rugged and weatherproof Ultra low wind loading and low visual impact Vertical or horizontal polarization Type N female connector Super HD bracket models available for greater stability ANTENNA PATTERNS Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com GD58-22 HPOL GD58-26 HPOL GD58-29 HPOL GD58-22 VPOL GD58-26 VPOL GD58-29 VPOL Grid Dish Parabolic Antenna GD5x SPECIFICATIONS PARAMETER Frequency range GD5x-21 GD58-22 GD5x-25 GD58-26 GD5x-28 GD58-29 GD57-21 GD57-25 GD57-28 5470-5725 MHz 5470-5725 MHz 5470-5725 MHz 5725-5850 MHz 5725-5850 MHz 5725-5850 MHz GD53-21 GD53-25 GD53-28 5150-5350 MHz 5150-5350 MHz 5150-5350 MHz Gain 21 dBi 22 dBi 25 dBi 26 dBi 28 dBi 29 dBi Horizontal beamwidth 10° 6° 4° Vertical beamwidth 11° 6° 6° 25 dB 30 dB 25 dB Front to back 1.5:1 1.5:1 1.5:1 Impedance 50 ohm 50 ohm 50 ohm Input power 100 watts 100 watts 100 watts -40° to +70°C -40° to +70°C -40° to +70°C Pole size 1 to 2 in (25 to 50 mm) 1 to 2 in (25 to 50 mm) 1 to 2 in (25 to 50 mm) Weight 3 lbs (1.4 kg) 6 lbs (2.7 kg) 11 lbs (5 kg) 11.8 x 15.7 in (300 x 400 16.8 x 24 in (427 x 610 28.5 x 36 in (724 x 914 mm)+/- 45° mm)+/- 45° mm)+/- 45° VSWR Operating temperature Dimension (W x L) Bracket tilt WIND LOADING (LBS.) MODEL 100 MPH 125 MPH 100 MPH WITH ½ IN RADIAL ICE GD58-22 10 lbs 15.6 lbs GD58-26 20 lbs 31 lbs 99 lbs GD58-29 41 lbs 64 lbs 257 lbs 48 lbs SYSTEM ORDERING GD58-22 GD58-26 GD58-29 GD57-21 GD57-25 5.7-5.8 GHz 22 dBi directional antenna 5.7-5.8 GHz 26 dBi directional antenna * 5.7-5.8 GHz 29 dBi directional antenna * 5.4-5.7 GHz 21 dBi directional antenna 5.4-5.7 GHz 25 dBi directional antenna * GD57-28 5.4-5.7 GHz 28 dBi directional antenna * GD53-21 5.1-5.3 GHz 21 dBi directional antenna GD53-25 5.1-5.3 GHz 25 dBi directional antenna * GD53-28 5.1-5.3 GHz 28 dBi directional antenna * NOTES • All shipments F.O.B. Schaumburg, IL 60173 * Super HD bracket system now available for large and medium grid. Add “HD” as prefix to part number Example: HDGD58-29 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-GD5x 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
GD53-21 价格&库存
很抱歉,暂时无法提供与“GD53-21”相匹配的价格&库存,您可以联系我们找货
