VA25-16M
VA25-16M
    LAIRD(莱尔德)
    ANT VAGI 16DBI 2.5-2.7G 24" N
VA25-16M 数据手册
WiMax Directional Antenna VA25-16 VAGI® SERIES: 2500 TO 2700 MHz OPERATION The Vagi® Series antenna system offered by Laird is constructed of die cast aluminum alloy with anti-corrosion alodine finish. They come standard with a choice of an N female or N male connector and an adjustable 45° tilt galvanized steel QuikClamp bracket which accommodates a 1 to 1.5 in pole diameter. The Vagi Series antenna can be used in a wide variety of wireless systems where low cost, good performance and low wind loading are important factors. Because of their low visual impact, they have been approved for use by many homeowner associations with strict CC&R restrictions. Various frequency options are available between 1700 and 2700 MHz (contact Laird for different frequency or connector options). FEATURES MARKETS • • • • • • • • • • • • • Compact, low profile 16 dBi antenna gain Low cost compared to other 16 dBi gain antennas Very low wind loading aesthetic design QuikClamp bracket for 1.0 to 1.5 in pole diameter 45° tilt and 360° rotation adjustments Vertical or horizontal polarization 24 in pigtail with type N female or N male connector • Rugged, lightweight and waterproof • Frequency options available between 1700 and 2700 Mhz ANTENNA PATTERN Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com WiMax applications Wireless broadband systems MMDS applications Wireless internet access Point to multi-point systems Building to building high speed links WiMax Directional Antenna VA25-16 SPECIFICATIONS PARAMETER MODEL MIN Frequency Range VA25-16 2500 Input Return Loss TYP MAX UNITS 2700 MHz -14 VSWR dB 1.5:1 Impedance 50 Input Power ohm 50 Pole Diameter (OD) Operating Temperature 1 (25) 1.5 (38) in (mm) -45 +70 °C *Note: Laird Technologies does not supply the mounting pole 2500-2700 MHz VA25-16 Gain 16 dB 3 db Beam Angle (E-Plane) Vertical Polarity 3 dB 25° Beam Angle (H-Plane) Horizontal Polarity 30° Front to Back > 19 dB Rated Wind Velocity 125 mph (56 m/sec) Weight 1.5 lbs (0.56 Kg) Dimension L x W x H 22 x 3 x 4 in (559 x 76 x 102 mm) SYSTEM ORDERING INFORMATION 16 dBi Vagi Series 2.4 GHz Antenna with N Male Connector 16 dBi Vagi Series 2.4 GHz Antenna with N Female Connector NOTES • All shipments F.O.B. Schaumburg, IL 60173 16 dBi Vagi Shown in Vertical Polarization ANT-DS-VA25-16 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
VA25-16M
物料型号:VA25-16M(N公头)和VA25-16F(N母头)
器件简介:Vagi®系列天线由Laird公司提供,采用压铸铝合金制成,具有防腐的Alodine涂层。标准配置包括N型公头或母头连接器和可调节45°倾斜的镀锌钢制QuikClamp支架,适用于直径1到1.5英寸的杆。
引脚分配:文档中未明确提及引脚分配,但提到了24英寸的尾缆和N型公头或母头连接器。
参数特性: - 频率范围:2500至2700 MHz - 输入回波损耗:最小-14 dB - 驻波比:1.5:1 - 阻抗:50欧姆 - 输入功率:50瓦 - 杆径(外径):1至1.5英寸 - 工作温度:-45至+70摄氏度
功能详解: - 增益:16 dBi - 3 dB波束宽度(E平面)垂直极化:25° - 波束宽度(H平面)水平极化:30° - 前后比:大于19 dB - 额定风速:125英里/小时(56米/秒) - 重量:1.5磅(0.56千克) - 尺寸:22x3x4英寸(559x76x102毫米)
应用信息:适用于WiMax应用、无线宽带系统、MMDS应用、无线互联网接入、点对多点系统、建筑物之间的高速链路。
封装信息:文档中未明确提及封装信息,但提供了天线的物理尺寸。
VA25-16M 价格&库存
很抱歉,暂时无法提供与“VA25-16M”相匹配的价格&库存,您可以联系我们找货
