GPSUW15M
GPSUW15M
    LAIRD(莱尔德)
    1.575GHz GPS Dome RF Antenna 26dB Connector, NMO Adhesive
GPSUW15M 数据手册
GPST821/18503P Laird GPS/Telematics antennas provide low profile, high performance and cost effective mobile communication solutions Laird GPS/Telematics antennas are low profile, high performance and costeffective solutions for your mobile communications needs. Available in combinations that cover all primary cellular frequencies plus GPS and Satellite Radio, Laird Technologies GPS/Telematic antennas feature small form factors allowing easy installation virtually anywhere inside or outside a vehicle. Phantom AVL/GPS antennas are currently utilized by ocean bound freighters monitoring temperature and data while withstanding extreme temperatures, salt water and vibration. With integrated research, tooling, molding, assembly and accelerated life testing facilities around the world, Laird Technologies’ engineers will quickly and efficiently create solutions to a multitude of wireless challenges. Model Description Center Freq Gain Overall Radio/GPS Coax Height Connector Type 450 - 470 MHz 746 - 786 MHz 806 - 866 MHz 806 - 866 MHz 821 - 896 MHz 890 - 960 MHz 902 - 928 MHz 3 dB-MEG 3 dB-MEG 3 dB-MEG 3 dB-MEG 3 dB-MEG 3 dB-MEG 3 dB-MEG 3.5” 1.25” 1.25” 1.25” 1.25” 1.25” 1.25” TNC/SMB TNC/SMB TNC/SMB TNC/SMB TNC/SMB TNC/SMB TNC/SMB RG58 RG58 RG58 RG58 RG58 RG58 RG58 821-896 MHz/ 1850-1990 MHz 821-896 MHz/ 1850-1990 MHz 3 dB-MEG 1.25” TNC/SMB RG174 3 dB-MEG 1.25” SMA/SMB RG174 Low profile multi-band GPS GPST821/18503P ® • Patented field diversity Phantom technology ensures uninterrupted voice and data transmissions in urban canyons and rural drop off areas • 27 dB active GPS patch with high sensitivity for accurate timing and locating • Low profile design prevents tampering and is visually pleasing Dual-Band GPS AVL GPSD4503P GPSD7463P GPSD8063P GPSD8063EP GPSD8213P GPSD8903P GPSD9023P Standard AVL w/Phantom* Low Profile AVL w/Phantom* Low Profile AVL w/Phantom* As above w/ext. 1” mounting nut Low Profile AVL w/Phantom* Low Profile AVL w/Phantom* Low Profile AVL w/Phantom* Tri-Band Low Profile GPS AVL GPST821/18503P Cell/PCS/GPS Low Profile* KIT1171-120 Cell/PCS/GPS Low Profile* Adhesive mount Other connector options available KIT1171-120 Adhesive mount option available on Low Profile GPS Antennas
GPSUW15M 价格&库存
很抱歉,暂时无法提供与“GPSUW15M”相匹配的价格&库存,您可以联系我们找货
