698-‐960
MHz/1710-‐2700
MHz
LTE
Vertical
Standard
Directional
Panel
Antenna
PAV69278I
LTE
MUTI-‐BAND
DIRECTIONAL
PANEL
ANTENNA
The
PAV69278I
is
a
multi-‐band,
high
gain
directional
panel
antenna
with
vertical
polarization
that
covers
the
698
960
MHz/1710
2700
MHz
LTE700/Cellular/PCS/AWS/
MDS
and
global
GSM900/
GSM1800
/UMTS/LTE2600
bands.
The
radiation
patterns
are
uniform
and
symmetrical,
providing
high-‐level
signal
density
into
defined
coverage
zones.
This
antenna
will
greatly
enhance
the
performance
of
LTE
systems
and
is
ideal
for
indoor
applications.
The
antenna
includes
a
wall
mounting
bracket,
anchors
and
bolts.
FEATURES
APPLICATIONS
• Performance
optimized
using
Laird
proprietary
RF
optimization
tools
• Mounts
easily
and
directly
to
wall
• UV
stable,
aesthetically
compact
Radome
with
excellent
flame
rating
• Engineered
for
superior
performance:
high
dBi
gain
and
excellent
VSWR
• Multiple
connector
and
coax
options
available
including
fixed
Type
N(f)
and
integrated
coax
pigtail
with
Type
N(f)
• Conformance
to
RoHS
• In-‐building
Wireless
Networks
• Wireless
Terminal,
Point-‐of-‐Sale,
and
Machine-‐to-‐Machine
• Automatic
meter
reading
• Commercial,
industrial
and
home
security
SPECIFICATIONS
Americas:
+1.847
839.6907
IAS-‐AmericasEastSales@lairdtech.com
Europe:
+44.1628.858941
IAS-‐EUSales@lairdtech.com
Asia:
+86.21.5855.0827.127
IAS-‐AsiaSales@lairdtech.com
www.lairdtech.com
PARAMETER
SPECIFICATION
MODEL
PAV69278I
Frequency
(MHz)
698-‐960
/1710-‐2700
Antenna
Type
Directional
Panel
Indoor
VSWR
Max
2.0:1
Gain
8
dBi
HP
Beam
Width
Azimuth
75°
63°
HP
Beam
Width
Elevation
64°
51°
Front
to
Back
Ratio
10
dB
25
dB
Polarization
Vertical
Plenum
Rated
Yes
Nominal
Impedance
50
Ω
Power
Watts
50
W
Enclosure
Material:
ABS
White
Dimensions
9.82
x
9.8
x
2.41
inches
249.4
x
248.6
x
61.3
mm
Mounting
Wall
Mount
Antenna
Weight
kg
(lbs.)
0.62
(1.35)
Operational
Temperature
-‐30°C
to
+70°C
Storage
Temperature
Material
Substance
Compliance
-‐40°C
to
+85°C
RoHS
698-‐960
MHz/1710-‐2700
MHz
LTE
Vertical
Standard
Directional
Panel
Antenna
PAV69278I
Radiation
Pattern
at
698
MHz
Azimuth
Plane
Azimuth
Plane
330
300
270
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
330
30
60
300
90
240
270
120
210
Radiation
Pattern
at
824
MHz
Phi
0°
PPlane
Elevation
lane
Azimuth
lane
Azimuth
PP
lane
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
300
60
90
240
150
330
30
120
210
270
150
330
300
270
30
330
60
300
90
240
270
120
210
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
150
330
30
300
60
90
270
300
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
330
300
90
240
120
150
180
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
150
180
Plane
Phi
Elevation
0°
Plane
30
330
60
300
90
270
120
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
30
60
90
240
150
120
210
150
180
180
Radiation
Pattern
at
2110
MHz
Azimuth
Plane
Azimuth
Plane
30
300
60
90
240
120
210
120
150
Phi
0°
PPlane
lane
Elevation
60
210
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
180
30
90
210
150
240
Radiation
Pattern
at
1880
MHz
330
60
240
Azimuth
PPlane
Azimuth
lane
Radiation
Pattern
at
1710
MHz
120
Azimuth
Plane
Azimuth
Plane
270
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
180
240
180
300
90
210
Phi
0°
PPlane
Elevation
lane
120
Radiation
Pattern
at
960
MHz
Azimuth
Plane
Azimuth
Plane
330
30
240
180
180
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
Phi
Elevation
0°
Plane
Plane
150
180
ANT-‐DS-‐PAV69278I_071614
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
Phi
0°
Plane
Elevation
Plane
330
60
300
90
240
120
210
150
180
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
60
90
240
120
210
150
180
2
Any
information
f urnished
by
L aird
and
its
agents
is
believed
to
be
accurate
and
reliable.
All
specifications
are
s ubject
to
change
without
notice.
Responsibility
for
the
use
and
application
of
L aird
m aterials
r ests
w ith
the
e nd
user,
since
L aird
and
its
agents
cannot
be
aware
of
all
potential
uses.
Laird
m akes
no
w arranties
as
to
the
fitness,
merchantability
or
suitability
of
any
Laird
m aterials
or
products
for
any
specific
or
general
uses.
Laird,
L aird
Technologies,
Inc
or
any
of
its
affiliates
or
agents
shall
not
be
liable
for
incidental
or
consequential
damages
of
any
kind.
All
L aird
products
are
sold
pursuant
to
the
L aird
Technologies’
Terms
and
Conditions
of
s ale
in
effect
from
time
to
time,
a
copy
of
w hich
w ill
be
furnished
upon
request.
Copyright
2 013
L aird
Technologies,
I nc.
All
Rights
R eserved.
L aird,
L aird
Technologies,
the
Laird
Technologies
L ogo,
and
other
marks
are
trademarks
or
registered
trademarks
of
L aird
Technologies,
Inc.
or
an
affiliate
company
thereof.
O ther
product
or
service
names
m ay
be
the
property
of
third
parties.
N othing
herein
provides
a
license
under
any
L aird
or
any
third
party
intellectual
property
rights.
698-‐960
MHz/1710-‐2700
MHz
LTE
Vertical
Standard
Directional
Panel
Antenna
PAV69278I
Radiation
Pattern
at
2305
MHz
Azimuth
Plane
Azimuth
Plane
330
300
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
330
30
60
300
90
120
210
Azimuth
lane
Azimuth
PP
lane
Phi
0°
PPlane
Elevation
lane
Radiation
Pattern
at
2412
MHz
270
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
300
60
90
240
150
330
30
120
210
Phi
Elevation
0°
Plane
Plane
30
60
300
90
240
120
210
150
150
180
180
180
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
60
90
240
120
210
150
180
Radiation
Pattern
at
2700
MHz
Azimuth
Plane
Azimuth
Plane
330
300
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
Elevation
Plane
Phi
0°
Plane
30
60
300
90
240
120
210
150
180
270
10
5
-‐5
-‐10
-‐15
-‐20
-‐25
-‐30
60
90
240
120
210
150
180
3
Any
information
f urnished
by
L aird
and
its
agents
is
believed
to
be
accurate
and
reliable.
All
specifications
are
s ubject
to
change
without
notice.
Responsibility
for
the
use
and
application
of
L aird
m aterials
r ests
w ith
the
e nd
user,
since
L aird
and
its
agents
cannot
be
aware
of
all
potential
uses.
Laird
m akes
no
w arranties
as
to
the
fitness,
merchantability
or
suitability
of
any
Laird
m aterials
or
products
for
any
specific
or
general
uses.
Laird,
L aird
Technologies,
Inc
or
any
of
its
affiliates
or
agents
shall
not
be
liable
for
incidental
or
consequential
damages
of
any
kind.
All
L aird
products
are
sold
pursuant
to
the
L aird
Technologies’
Terms
and
Conditions
of
s ale
in
effect
from
time
to
time,
a
copy
of
w hich
w ill
be
furnished
upon
request.
Copyright
2 013
L aird
Technologies,
I nc.
All
Rights
R eserved.
L aird,
L aird
Technologies,
the
Laird
Technologies
L ogo,
and
other
marks
are
trademarks
or
registered
trademarks
of
L aird
Technologies,
Inc.
or
an
affiliate
company
thereof.
O ther
product
or
service
names
m ay
be
the
property
of
third
parties.
N othing
herein
provides
a
license
under
any
L aird
or
any
third
party
intellectual
property
rights.
很抱歉,暂时无法提供与“PAV69278I-FNF”相匹配的价格&库存,您可以联系我们找货
