PAV69278I-30NF
PAV69278I-30NF
    LAIRD(莱尔德)
    ANTENNAPNLLTEVERTSTD
PAV69278I-30NF 数据手册
698-­‐960  MHz/1710-­‐2700  MHz   LTE  Vertical  Standard  Directional  Panel  Antenna PAV69278I   LTE  MUTI-­‐BAND  DIRECTIONAL  PANEL  ANTENNA   The  PAV69278I  is  a  multi-­‐band,  high  gain  directional  panel  antenna  with  vertical  polarization   that  covers  the  698  –  960  MHz/1710  –  2700  MHz  LTE700/Cellular/PCS/AWS/  MDS  and  global   GSM900/  GSM1800  /UMTS/LTE2600  bands.  The  radiation  patterns  are  uniform  and   symmetrical,  providing  high-­‐level  signal  density  into  defined  coverage  zones.  This  antenna  will   greatly  enhance  the  performance  of  LTE  systems  and  is  ideal  for  indoor  applications.  The   antenna  includes  a  wall  mounting  bracket,  anchors  and  bolts.     FEATURES   APPLICATIONS   • Performance  optimized  using  Laird proprietary  RF  optimization  tools • Mounts  easily  and  directly  to  wall • UV  stable,  aesthetically  compact Radome  with  excellent  flame  rating • Engineered  for  superior  performance: high  dBi  gain  and  excellent  VSWR • Multiple  connector  and  coax  options available  including    fixed  Type  N(f)  and integrated  coax  pigtail  with  Type  N(f) • Conformance  to  RoHS • In-­‐building  Wireless  Networks • Wireless  Terminal,  Point-­‐of-­‐Sale, and  Machine-­‐to-­‐Machine • Automatic  meter  reading • Commercial,  industrial  and home  security SPECIFICATIONS   Americas:  +1.847  839.6907   IAS-­‐AmericasEastSales@lairdtech.com   Europe:  +44.1628.858941   IAS-­‐EUSales@lairdtech.com    Asia:  +86.21.5855.0827.127     IAS-­‐AsiaSales@lairdtech.com     www.lairdtech.com   PARAMETER    SPECIFICATION    MODEL  PAV69278I         Frequency  (MHz)   698-­‐960  /1710-­‐2700   Antenna  Type   Directional  Panel  Indoor   VSWR  Max   <  2.0:1   Gain   8  dBi   HP  Beam  Width  Azimuth   75°  /  63°   HP  Beam  Width  Elevation   64°  /  51°   Front  to  Back  Ratio   10  dB  /  25  dB   Polarization   Vertical   Plenum  Rated   Yes   Nominal  Impedance   50  Ω   Power  Watts   50  W   Enclosure   Material:  ABS  White   Dimensions   9.82  x  9.8  x  2.41  inches   249.4  x  248.6  x  61.3  mm   Mounting   Wall  Mount   Antenna  Weight  kg  (lbs.)   0.62  (1.35)   Operational  Temperature   -­‐30°C  to  +70°C   Storage  Temperature   Material  Substance   Compliance   -­‐40°C  to  +85°C   RoHS   698-­‐960  MHz/1710-­‐2700  MHz   LTE  Vertical  Standard  Directional  Panel  Antenna PAV69278I   Radiation  Pattern  at  698  MHz   Azimuth   Plane   Azimuth  Plane 330 300 270 0 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 330 30 60 300 90 240 270 120 210 Radiation  Pattern  at  824  MHz   Phi   0°  PPlane Elevation   lane   Azimuth   lane   Azimuth  PP lane 0 0 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 300 60 90 240 150 330 30 120 210 270 150 330 300 270 30 330 60 300 90 240 270 120 210 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 150 330 30 300 60 90 270 300 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 330 300 90 240 120 150 180 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 150 180 Plane   Phi  Elevation   0°  Plane 30 330 60 300 90 270 120 0 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 30 60 90 240 150 120 210 150 180 180 Radiation  Pattern  at  2110  MHz   Azimuth   Plane   Azimuth  Plane 0 330 30 300 60 90 240 120 210 120 0 210 150 Phi   0°  PPlane lane   Elevation   60 210 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 180 30 90 210 150 240 Radiation  Pattern  at  1880  MHz   330 60 240 Azimuth  PPlane Azimuth   lane   0 210 0 30 Radiation  Pattern  at  1710  MHz   120 Azimuth   Plane   Azimuth  Plane 270 0 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 180 240 180 300 90 210 Phi   0°  PPlane Elevation   lane   0 60 120 Radiation  Pattern  at  960  MHz   Azimuth   Plane   Azimuth  Plane 330 30 240 180 180 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 Phi  Elevation   0°  Plane Plane   150 180 ANT-­‐DS-­‐PAV69278I_071614   270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 Phi   0°  Plane   Elevation  Plane 0 30 330 60 300 90 240 120 210 150 180 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 0 30 60 90 240 120 210 150 180 2   Any  information  f urnished  by  L aird  and  its  agents  is  believed  to  be  accurate  and  reliable.  All  specifications  are  s ubject  to  change  without  notice.  Responsibility  for  the     use  and  application  of  L aird  m aterials  r ests  w ith  the  e nd  user,  since  L aird  and  its  agents  cannot  be  aware  of  all  potential  uses.  Laird  m akes  no  w arranties  as  to  the  fitness,   merchantability  or  suitability  of  any  Laird  m aterials  or  products  for  any  specific  or  general  uses.  Laird,  L aird  Technologies,  Inc  or  any  of  its  affiliates  or  agents  shall  not  be  liable   for  incidental  or  consequential  damages  of  any  kind.  All  L aird  products  are  sold  pursuant  to  the  L aird  Technologies’  Terms  and  Conditions  of  s ale  in  effect  from  time  to  time,  a   copy  of  w hich  w ill  be  furnished  upon  request.  ©  Copyright  2 013  L aird  Technologies,  I nc.  All  Rights  R eserved.  L aird,  L aird  Technologies,  the  Laird  Technologies  L ogo,  and  other   marks  are  trademarks  or  registered  trademarks  of  L aird  Technologies,  Inc.  or  an  affiliate  company  thereof.  O ther  product  or  service  names  m ay  be  the  property  of     third  parties.  N othing  herein  provides  a  license  under  any  L aird  or  any  third  party  intellectual  property  rights.     698-­‐960  MHz/1710-­‐2700  MHz   LTE  Vertical  Standard  Directional  Panel  Antenna PAV69278I   Radiation  Pattern  at  2305  MHz   Azimuth   Plane   Azimuth  Plane 330 300 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 330 30 60 300 90 120 210 Azimuth   lane   Azimuth  PP lane Phi   0°  PPlane Elevation   lane   0 240 Radiation  Pattern  at  2412  MHz   270 0 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 300 60 90 240 150 330 30 120 210 Phi  Elevation   0°  Plane   Plane 0 330 30 60 300 90 240 120 210 150 150 180 180 180 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 0 30 60 90 240 120 210 150 180 Radiation  Pattern  at  2700  MHz   Azimuth  Plane Azimuth   Plane   330 300 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 Elevation  Plane Phi   0°  Plane   0 330 30 60 300 90 240 120 210 150 180 270 10 5 0 -­‐5 -­‐10 -­‐15 -­‐20 -­‐25 -­‐30 0 30 60 90 240 120 210 150 180 ANT-­‐DS-­‐PAV69278I_071614   3   Any  information  f urnished  by  L aird  and  its  agents  is  believed  to  be  accurate  and  reliable.  All  specifications  are  s ubject  to  change  without  notice.  Responsibility  for  the     use  and  application  of  L aird  m aterials  r ests  w ith  the  e nd  user,  since  L aird  and  its  agents  cannot  be  aware  of  all  potential  uses.  Laird  m akes  no  w arranties  as  to  the  fitness,   merchantability  or  suitability  of  any  Laird  m aterials  or  products  for  any  specific  or  general  uses.  Laird,  L aird  Technologies,  Inc  or  any  of  its  affiliates  or  agents  shall  not  be  liable   for  incidental  or  consequential  damages  of  any  kind.  All  L aird  products  are  sold  pursuant  to  the  L aird  Technologies’  Terms  and  Conditions  of  s ale  in  effect  from  time  to  time,  a   copy  of  w hich  w ill  be  furnished  upon  request.  ©  Copyright  2 013  L aird  Technologies,  I nc.  All  Rights  R eserved.  L aird,  L aird  Technologies,  the  Laird  Technologies  L ogo,  and  other   marks  are  trademarks  or  registered  trademarks  of  L aird  Technologies,  Inc.  or  an  affiliate  company  thereof.  O ther  product  or  service  names  m ay  be  the  property  of     third  parties.  N othing  herein  provides  a  license  under  any  L aird  or  any  third  party  intellectual  property  rights.
PAV69278I-30NF 价格&库存
很抱歉,暂时无法提供与“PAV69278I-30NF”相匹配的价格&库存,您可以联系我们找货
