S1718AMP10TNF
S1718AMP10TNF
    LAIRD(莱尔德)
    ANT 1710-1880MHZ 7.5DBI TNC FML
S1718AMP10TNF 数据手册
Laird Technologies - Item # S1718AMP10TNF, DirectLink™ Series Antennas Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > DirectLink™ Series Antennas > Item # S1718AMP10TNF Item # S1718AMP10TNF, DirectLink™ Series Antennas Campus & in-building directional antennas DirectLink is a series of wall and mast mount directional antennas that has been designed to meet the most demanding needs of the contemporary wireless environment. DirectLink's attractive, UV resistant housings and mounts allow the antennas to be mounted anywhere in the larger image campus or in-building environment. The antennas offer very precise and controllable pattern characteristics in frequencies starting with the 1710 MHz DCS band and continuing through the 5.725 GHz ISM band. All popular contemporary wireless system applications are covered with gain characteristics varying with frequency. All antennas in the series may be wall or mast mounted and all are available with a variety of flush and articulating mounts. Flush mounts allow the antenna to hug the wall for minimal visual impact. There are two available articulating mounts that allow the pattern to be directed while still maintaining minimal visual impact. Standard antennas come with either TNC, SMA or N female connectors and an integrated coaxial pigtail. Other connector and pigtail combinations are available upon request. Specifications Band DCS ISM Frequency 1710 to 1880 MHz Gain 7.5 dBi 3dB Beamwidth, E Plane 60 º 3dB Beamwidth, H Plane 85 º VSWR 1.5:1 Front to Back Ratio 12 dB Connector TNC (Female) Articulating Version Yes Power 75 watts Power at 5 GHz 25 watts Polarization Linear http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/directlink-trade-series-anten... 8/8/2012 Laird Technologies - Item # S1718AMP10TNF, DirectLink™ Series Antennas Page 2 of 2 Standard Wall Mount Dimension 5.70 x 3.81 x 1.50 in 14.48 x 9.68 x 3.80 cm Articulating Wall Mount Dimension 5.80 x 3.81 x 2.26 in 14.73 x 9.68 x 5.74 cm Weight (Standard Wall Mount) 5 oz 0.14 kg Weight (Articulating Wall Mount) 8 oz 0.23 kg Mounting Style Standard units for wall mounting. Mast mount bracket kits available. Custom mount configurations for volume users. Cable Low loss pigtail provided http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/directlink-trade-series-anten... 8/8/2012
S1718AMP10TNF 价格&库存
很抱歉,暂时无法提供与“S1718AMP10TNF”相匹配的价格&库存,您可以联系我们找货
