S1800BNF
S1800BNF
    LAIRD(莱尔德)
    ANT 1850-1990MHZ 2.5DBI N FML
S1800BNF 数据手册
Laird Technologies - Item # S1800BNF, Special Purpose Omnidirectional Antennas Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > Laird Technologies Dual Feed, Linear & Circular Panel Antennas (CELL) > Special Purpose Omnidirectional Antennas > Item # S1800BNF Item # S1800BNF, Special Purpose Omnidirectional Antennas Omnidirectional Antennas for PCS/DCS and Wireless LAN Laird Technologies is world renowned for its special purpose omnidirectional antenna designs. Antennas are available for frequencies from the 1.7 GHz DCS band through the 5.8 GHz ISM band and can either be suspension ceiling mounted, I-beam mounted or mast mounted. 2.4 GHz Monopole Omni The Laird Technologies 2.4 GHz monopole antenna has a large backplane and is designed for applications with a very focused larger image omnidirectional pattern where an in-building system is required. For example, the monopole could be used to focus signal directly into an area where it is very difficult to get any coverage. Specifications Band DCS PCS Frequency 1850 to 1990 MHz Gain 0 dBD VSWR 1.5:1 Bandwidth 140 MHz 3dB Beamwidth, E Plane 70 º Height 8 in 20.3 cm Weight 1.2 lbs 0.55 kg Wind Surface Area 0.04 m2 0.003 ft2 Wind Survival 125 mph 200 kph Power 50 watts http://lairdtech.thomasnet.com/printitem/all-categories/special-purpose-omnidirectional-ante... 8/8/2012 Laird Technologies - Item # S1800BNF, Special Purpose Omnidirectional Antennas Enclosure Material Polycarbonate Mounting Style Direct Mount RF Connector N (Female) Pigtail 12 in 30.5 cm Element Material Printed Circuit - Radome Dia. 1” Page 2 of 2 http://lairdtech.thomasnet.com/printitem/all-categories/special-purpose-omnidirectional-ante... 8/8/2012
S1800BNF 价格&库存
很抱歉,暂时无法提供与“S1800BNF”相匹配的价格&库存,您可以联系我们找货
