B1322WS
B1322WS
    LAIRD(莱尔德)
    ANT MOBILE COIL VHF 132-174MHZ
B1322WS 数据手册
Wide Band Mobile Load Coil Antenna B1322W PREMIUM MOBILE LOAD COIL ANTENNAS ARE INDUSTRY STANDARD Laird's ongoing commitment to refinement in mechanical and electrical design has resulted in the most technically advanced mobile load coil antennas on the market. Exclusive features such as stainless steel whips, housings constructed with ABS material injected molded around a solid brass insert, and gold plated push pin contacts make Laird the obvious choice for quality and long lasting value for demanding mobile radio communications. FEATURES MARKETS • High performance wide band mobile antenna • Public safety • Special UV treated radome, resists sun damage • Utility • Transportation • Easy installation with optional NMO Mounts • Military mobile • 100% tested on a network analyzer • Field  tunable to your specific frequency requirement (cutting chart comes with the antenna) SPECIFICATIONS ELECTRICAL Frequency range 2.4dB Bandwidth 23 MHz Maxmium power Nominal impedance 50 Ω VSWR
B1322WS 价格&库存
很抱歉,暂时无法提供与“B1322WS”相匹配的价格&库存,您可以联系我们找货
