Phantom®
UHF Antennas
PHANTOM® UHF ANTENNA OUTPERFORMS CONVENTIONAL MOBILE
ANTENNAS IN MANY APPLICATIONS
Laird's unique patented Phantom® is a tough antenna for outdoor or indoor applications.
Measuring only 3.4” tall, the Phantom UHF antenna’s revolutionary design features vertical
polarization components. The Phantom®provides low visibility, wide bandwidth and a low
angle radiation pattern that is superior to traditional gain antennas in most applications.
The industry standard NMO mounting socket mates with all Laird magnetic, trunk lid, and
hole mounts. A threaded permanent stud mount model is also available for vandal resistant
mounting on brackets, panels, ceilings or any other kind of housing.
The Phantom® patented technology is beneficial when high performance is desired and
extreme ruggedness and low profile is required.
FEATURES
MARKETS
• Phantom outperforms a 3dB whip in
many applications
• Public safety
• U.S. Patent Nos. 5,977,931 – 6,292,156
and 7,209,096
• Utility
• Transportation
• Military mobile
• Fixed radio applications
SPECIFICATIONS
ELECTRICAL
VSWR (Measured on 2’ x 2’ GP)
Peak Gain
3 dBi
Maximum Power
100 W
Nominal Impedance
Polarization
Pattern
Half-Power Beamwidth
(Elevation° x Azimuth°)
Coaxial Cable Length & Type
Terminations
Noise Suppressor
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
< 1.5:1 @ 10 MHz
< 2.0:1 @ 20 MHz
50 Ω
Vertical
Omnidirectional
146° x 360°
None
NMO
BlackHawk NS1535 1-35 VOLT, 15 Amp
Noise Suppessor (Sold Separately)
Phantom®
UHF Antennas
SPECIFICATIONS
FORM FACTOR DRAWING
MECHANICAL
3½” *
Height (initially)
Diameter
1.438”
Weight
0.21 lbs.
Rated Wind Velocity
125mph (210 kph)
Rated Wind Velocity
(with 0.5” radial ice)
85mph (137 kph)
Lateral Thrust @ 125mph
Wind Velocity
57 lbs. (26kg)
Wind Resistance in Sq. Feet
0.0356 Sq. ft.
Material
ABS
Mounting Information
NMO or Permanent Mountable
* Add .835” for Permanent Mount option
Permanent Mounting Option:
Please order by antenna model and insert letter “P” to indicate permanent mounting
option (TRA4503P).
MODEL AND ORDERING INFORMATION
MODEL
DESCRIPTION
TRA3003
300-305 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB3003
300-305 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA3803
380-400 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB3803
380-400 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4063
406-425 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4063
406-425 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4103
410-430 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4103
410-430 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4303
430-450 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4303
430-450 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4503
450-470 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4503
450-470 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4703
470-490 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4703
470-490 MHz 3 dBi Phantom® ¾ NMO, Black Radome
TRA4903
490-512 MHz 3 dBi Phantom® ¾ NMO, White Radome
TRAB4903
490-512 MHz 3 dBi Phantom® ¾ NMO, Black Radome
Sealtube3
Heat shrink tubing 3”x1”DIA Elite install
(use for jaw protector on installation wrench)
ANT-DS-PHANTOM UHF 0615
Any information furnished by Laird, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of
Laird materials rests with the end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or products for any specific or general uses.
Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which
will be furnished upon request. © Copyright 2015 Laird, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of
Laird, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party
intellectual property rights.
很抱歉,暂时无法提供与“TRAB3803P”相匹配的价格&库存,您可以联系我们找货
