TRA4501S3CW-001
TRA4501S3CW-001
    LAIRD(莱尔德)
    ANTENNADOME460MHZSMAMALE
TRA4501S3CW-001 数据手册
Phantom® TRA4501S3CW - UHF Antenna PHANTOM® UHF ANTENNA OUTPERFORMS CONVENTIONAL MOBILE ANTENNAS IN MANY APPLICATIONS The Laird unique patented Phantom® is a tough antenna for outdoor or indoor applications. Measuring only 3.4” tall, the Phantom UHF antenna’s revolutionary design features field diversity with both vertical and horizontal polarization components. This gives the antenna diversity, frequency agility, low visibility, wide bandwidth and a low angle radiation pattern that is superior to traditional gain antennas in most applications. The TRA4501S3CW-001 is available with an SMA (SubMiniature version A) connector. FEATURES MARKETS • True Field Diversity design ensures uninterrupted transmissions in urban canyons and rural drop off areas • Public safety • Phantom® outperforms a 3dB whip in many applications • U.S. Patent Nos. 5,977,931 – 6,292,156 and 7,209,096 • Transportation • Utility • Military mobile • Fixed radio applications SPECIFICATION ELECTRICIAL MECHANICAL < 1.5:1 @ 10 MHz < 2.0:1 @ 20 MHz Nominal Gain 3 dB MEG Maximum Power 100 W Nominal Impedance 50 Ω Vertical & Horizontal Omnidirectional Half-Power Beamwidth (Elevation° x Azimuth°) 146° x 360° Coaxial Cable &Type Pigtail Termination SMA 1.438” Rated Wind Velocity 125mph (210 kph) Rated Wind Velocity (with 0.5” radial ice) 85mph (137 kph) Lateral Thrust @ 125mph Wind Velocity 57 lbs. (26kg) Wind Resistance in Sq. Feet 0.0356 Sq. ft. Material ABS Mounting Information: Permanent Mount * Add .835” for Permanent Mount option BlackHawk NS1535 1-35 VOLT, 15 Amp Noise Suppessor (Sold Separately) MODEL AND ORDERING INFORMATION DESCRIPTION MODEL 450-470 MHz 3 dB-MEG Phantom SMA, P-Mount ,Black Radome TRA4501S3CW ° 30 23 0° 10° 40 ° 0° 33 0° ° 0° 350° 32 250 0° 0° 0° ° 1 170° ° 80 19 ° 0° 160 15 90° ° 13 0° 14 80 ° 110 24 ° ° 80° 90 ° 100° 260° 0 33 30 ° 27 0° 280° 0° 20° ° 40 ° 70° 12 200 0° 31 0° 30 ° 290 ° 280 72 0 ° www.lairdtech.com 70° 21 0° Asia: AsiaSales@lairdtech.com ° 60 ° 60 -2 0 -3 -0 -5 4 0 0 0° Europe: +44.1628.858941 IAS-EUSales@lairdtech.com ° 50 ° 50 22 -2 0 -3 -04 -5 0 0 290 -6 -8 -1 0 Elevation Pattern (Y, Z, or H-plane) Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com 0° -4 30 32 0° 0 -2 0 2 4 6 -1 8 0 31 ° 340 ANTENNA PATTERNS 10° Noise Suppressor Diameter 20° Pattern 3½” * 340 Polarization Height (initially) 350° VSWR Azimuth Pattern (X,Y, or E-plane) Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. ANT-DS-PHANTOM 0216 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
TRA4501S3CW-001 价格&库存
很抱歉,暂时无法提供与“TRA4501S3CW-001”相匹配的价格&库存,您可以联系我们找货
