WPD136M6B-001
WPD136M6B-001
    LAIRD(莱尔德)
    WHIPMCCC136380760MULTIBK
WPD136M6B-001 数据手册
Multi-Band Mobile Antenna WPD136M6C-001 LAIRD'S NEW FULL-SPECTRUM MULTI-BAND ANTENNA The WPD136M6C-001 multi-band mobile antenna Patent No. US7488902 is a commercial, heavy-duty vehicular antenna. It has an omnidirectional pattern and is vertically polarized with a 50Ω match. It also has excellent quality & RF performance, and is specifically designed as a full spectrum public safety voice & data communications antenna. FEATURES BENEFITS • Frequency range: 136-174/380-520/760-870 MHz • VSWR (at cable end) < 2.0:1 (typical), < 2.7:1 (at band edges, max) • High-performance, broad- • Unity gain • Omnidirectional, vertically polarized Patent No. US7488902 • Power: 100 W (max, PTT = 30 minutes) • Dimensions: 2.5” Round Base, 20” tall • Radome material: high impact PC/ABS • Textured finish • IP66 rated • Heavy-duty, chrome plated, spring loaded ferrule, 17-7 ph stainless steel tempered antenna whips, spring-loaded gold plated contact, and stainless steel antenna rod spring • NMO Style Mount banded, multi-band coverage • Heavy-duty design • Injection molded housing and base • No base radiators (all enclosed coils) • Solid brass chrome plated ferrules with dual set screw lock MARKETS OR APPLICATIONS •  General analog & digital voice/ data communications • VHF (high), UHF, 700/800 • Tetra PMR & P25 Public Safety • Transportation, Utilities, Government, Military, PAMR, Commercial & Industry, Oil & Gas ANTENNA PATTERNS Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Azimuth Cut, Phi = 0° 156 MHz Azimuth Cut, Phi = 0° 440 MHz Azimuth Cut, Phi = 0° 815 MHz Elevation Cut, Phi = 90° 156 MHz Elevation Cut, Phi = 90° 440 MHz Elevation Cut, Phi = 90° 815 MHz Multi-Band Mobile Antenna WPD136M6C-001 SPECIFICATIONS PARAMETER WPD136M6C-001 Pattern Omnidirectional Maximum Power 100 W Nominal Impedance 50 ohm Polarization Vertical VSWR ≤ 2.5:1 Termination NMO ANTENNA ELECTRICAL SPECIFICATIONS FREQUENCY BAND (MHz) 136-174 MHz Frequency Range (MHz), (Test Frequency) PEAK GAIN (dBi), PEAK GAIN (dBi), ELEVATION AZIMUTH Azimuth Cut, Elevation Cut, BEAMWIDTH AT BEAMWIDTH AT Phi =0° Phi = 90° HALF-POWER HALF-POWER 136, 156, 174 -0.7 380-520 MHz 380, 440, 520 -3.7 760-870 MHz 760, 815, 870 3.1 0.2 90° 360° 4.8 40° 360° 8.1 60° 360° UHF BAND: 380-520 MHZ VHF BAND: 136-174 MHZ ELEVATION PATTERN PEAK GAIN (DBI) AZIMUTH PATTERN -2.4 0.2 380 MHz -11.3 6.1 -2.7 -1.8 400 MHz -7 7.7 156 MHz -0.7 -3.1 440 MHz -4.1 4.8 174 MHz -3.5 -4.1 460 MHz -3.7 3 500 MHz -5.5 3.3 520 MHz -6.6 3.5 PEAK GAIN (DBI) AZIMUTH PATTERN 136 MHz 146 MHz UHF BAND: 760-870 MHZ PEAK GAIN (DBI) AZIMUTH PATTERN ELEVATION PATTERN 760 MHz 3.1 3.1 815 MHz -0.2 7.9 870 MHz -8.8 8.1 ELEVATION PATTERN ANT-DS-WPD136M6C-001 0915 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
WPD136M6B-001 价格&库存
很抱歉,暂时无法提供与“WPD136M6B-001”相匹配的价格&库存,您可以联系我们找货
