Laird Technologies - Item # PC8010N, 800 MHz Models - ESMR, SMR, Cellular, GSM ... Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Antennas & Reception Solutions > Vehicular Antennas & Telematics > Cellular Antennas > Dual
Band & Special Applications Antennas > PCS/DCS and 2.4 GHz ISM band Yagi antennas > 800 MHz Models ESMR, SMR, Cellular, GSM and Conventional > Item # PC8010N
Item # PC8010N, 800 MHz Models - ESMR, SMR, Cellular, GSM and Conventional
For 800 MHz ESMR and SMR or conventional applications, choose 4 element PC804N, 6 element PC806N or ten
element PC8010N. The Cushcraft PC804N, PC826N and PC8210N are also available in the 900 MHz GSM
frequency band.
larger image
larger image
Specifications
Band
GSM
SMR
ESMR
Celluar
Conventional
Frequency
806 to 869 MHz
Gain
11 dBD
No. of Elements
10
Front to Back Ratio
20 dB
3dB Beamwidth, E Plane
40 º
3dB Beamwidth, H Plane
45 º
http://lairdtech.thomasnet.com/printitem/cpe-antennas-wimax-3g-4g-lte-cellular-bwa-/-mhz-... 8/8/2012
Laird Technologies - Item # PC8010N, 800 MHz Models - ESMR, SMR, Cellular, GSM ... Page 2 of 2
RF Connector
N (Female)
Wind Surface Area
0.38 m2
0.035 ft2
Wind Survival
125 mph
200 kph
W/ 1/2" Ice
100 mph
161 kph
Length
46 in
116.8 cm
Weight
2.44 lbs
1.10 kg
Power
200 watts
Element Material
1/4 in (0.63 cm) 6061T6 Aluminum Rod
Boom Material
3/4 in (1.9 cm) 6061T6 Aluminum Channel
Mounting Style
U Bolt
Max. Mast Diameter
2 1/8 in
5.4 cm
Pigtail
19 in
48.3 cm
很抱歉,暂时无法提供与“PC8010N”相匹配的价格&库存,您可以联系我们找货
