Grid Dish Parabolic Antenna
GD24
2400 TO 2485 MHz GRID DISH PARABOLIC ANTENNA
The 2.4 GHz parabolic grid directional antennas offered by Laird utilize a patented parabolic
grid design with a patented high performance dipole feed. The antennas are constructed of
welded steel wires which are galvanized and then powder coat painted with a light gray
epoxy paint. The wire grid semi-parabolic design offers unsurpassed low wind loading while
maintaining good RF performance. The compact low visual impact attractive styling blends
well in almost any application. Mounting is simplified with the Laird bracket system made of
galvanized steel with stainless steel hardware. A super heavy duty “HD” bracket system is
available for the 24 dB grid. The antennas come with a 30 inch pigtail with choice of N male,
N female or RPSMA connector.
FEATURES
MARKETS
15 dBi, 19 dBi, and 24 dBi models available
Rugged and weatherproof
Ultra low wind loading and low visual impact
Vertical or horizontal polarization
Various connector choices
Super HD bracket 2 dBi model
available for greater stability
2.4 GHz wireless LAN applications
Client antennas
802.11b/g applications
Point-to-point backhaul
WiMAX
ANTENNA PATTERN
GD24-15
2450.0 MHz
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
GD24-19
2450.0 MHz
GD24-24
2450.0 MHz
GD24
SPECIFICATIONS
PARAMETER
GD24-15
GD24-19
GD24-24
2400-2485 MHz
2400-2485 MHz
2400-2485 MHz
15 dBi
19 dBi
24 dBi
17° vert., 21° hor.
11° vert., 17° hor.
8° vert., 10° hor.
Front to back
17 dB
22 dB
25 dB
VSWR
1.5:1
1.5:1
1.5:1
50 ohm
50 ohm
50 ohm
Frequency range
Gain
3dB beamwidth
Impedance
Input power
Operating temperature
Pole size
100 watts
100 watts
100 watts
-40° to +70°C
-40° to +70°C
-40° to +70°C
1 to 2 in (25 to 50 mm)
Weight
4 lbs (1.8 kg)
Dimension (W x L)
6 lbs (2.7 kg)
12 x 16 in (305 x 406 mm)
Bracket tilt
11 lbs (5 kg)
16.5 x 24 in (419 x 610 mm)
45°
28.5 x 36 in (724 x 914 mm)
45°
45°
WIND LOADING (LBS.)
MODEL
SQ. IN
100 MPH
125 MPH
100 MPH WITH ½ IN RADIAL ICE
GD24-15
40
10 lbs
15.6 lbs
48 lbs
GD24-19
79
20 lbs
31 lbs
99 lbs
GD24-24
163
41 lbs
64 lbs
257 lbs
15
19
24
NM (N male)
NF (N female)
RSMA (RPSMA)
NOTES
• All shipments F.O.B. Schaumburg, IL 60173
* Super HD Bracket System Now Available for 24 dBi Grid.
Add “HD” as prefix to part number. Example:
HDGD24-24P-NF
www.lairdtech.com
ANT-DS-GD24 0115
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice.
Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes
no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for
incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a
copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are
trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties.
Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“GD24-24P-NM-EZ”相匹配的价格&库存,您可以联系我们找货
