450 MHz MicroSphere Antenna
IF450
a
The widespread use of cellular phones and wireless network applications inside buildings has increased the
need for antenna systems that can provide considerable gain over traditional dipole antennas.
Laird's in-building wireless antennas are particularly applicable in environments where aesthetics and wide
angle coverage are necessary for successful wireless deployment. Their surprisingly small size allow the
antennas to be hidden almost anywhere, providing an invisible solution for most applications.
s
s
• Surprisingly small size allows it to be hidden almost anywhere, • The UHF band antenna is a good solution for stealth
in-building public safety systems.
providing an invisible solution for many applications.
• The field pattern is toroidal, providing omni-directional
s
coverage in any plane around the long axis of the antenna,
and two lobes in any plane parallel to the long axis.
s
Azimuth Plane
Cut perpendicular to the antenna,
parallel to the connector/cable exit,
perpendicular to the polarization
Element Type
Microstrip
Frequency Range
410-520 MHz (UHF)
Peak Gain
3 dBi
Polarization
Linear
Impedance
50 ohms
Maximum Input Power
10 watts
VSWR
2:1 Typical across the band
Dimensions (L x W x H)
13 x 14.7 x .25 cm
Housing
Acrylic
Operating/Storage Temperature
C
MODEL #
REFERENCE #
CONNECTOR
IF450-SF00
CAF94350
SMA Female Panel
s
• Includes nylon screws for mounting to ceiling tile or finished ceiling
Elevation Plane
parallel to the polarization axis
Omni Plane
Cut in the plane of the antenna
perpendicular to the connector/cable exit
Americas: +1.847 839.6907
IAS‐AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS‐EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS‐AsiaSales@lairdtech.com
www.lairdtech.com
ANT-DS-IF450 0615
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or
suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold
pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird,
Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the
property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“CAF94350”相匹配的价格&库存,您可以联系我们找货
