SL82184P12NF
SL82184P12NF
    LAIRD(莱尔德)
    ANTENNA 850-1900MHZ 4DBI N FML
SL82184P12NF 数据手册
Laird Technologies - Item # SL82184P12NF, Dual band 800 MHz/1900 MHz, 900 MHz/... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > Item # SL82184P12NF Item # SL82184P12NF, Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna The SL82184P12NF is Cushcraft's latest edition to its line of high performance ceiling mounted omnidirectional panel antennas. Although only 6" x 6" x 1.25" size, the antenna offers the performance characteristics of antennas twice its size. The antenna's extremely uniform and symmetrical pattern characteristic allows systems engineers to design their in-building wireless systems in confidence. The larger image SL82184P12NF delivers maximum energy where it is needed most and does it very consistently from one antenna to the next regardless of the RF characteristics of the surface that it is mounted to. The antenna has two coax pigtails, one for each band, thus eliminating the extra cost and complexity of a diplexer. The antenna is perfect for use in airports, business, industrial, commercial and educational campuses and any other in- building dual band carrier frequency applications. Contact your Cushcraft sales representative to discuss cable length and connector type options. Specifications Band Dual Band Frequency 824 to 896 MHz 1850 to 1990 MHz Max. VSWR 2:1 Average Gain (45º Horizontal) -0.5 dBi Peak Gain (Nom. At 90º Horizontal) 4.0 dBi Polarization Linear Weight (With 12" Cable) 0.75 lbs 0.34 kg Mounting Style Ceiling Dimensions 6 x 6 x 1.25 in 15.2 x 15.2 x 3.2 cm Enclosure Material ABS http://lairdtech.thomasnet.com/printitem/all-categories/mhz-1700-mhz-4-dbi-ceiling-omnidi... 8/8/2012 Laird Technologies - Item # SL82184P12NF, Dual band 800 MHz/1900 MHz, 900 MHz/... Page 2 of 2 Power 10 watts RF Connector Type N (Female) Pigtail 12 in http://lairdtech.thomasnet.com/printitem/all-categories/mhz-1700-mhz-4-dbi-ceiling-omnidi... 8/8/2012
SL82184P12NF 价格&库存
很抱歉,暂时无法提供与“SL82184P12NF”相匹配的价格&库存,您可以联系我们找货
