PC8210N
PC8210N
    LAIRD(莱尔德)
    ANTENNA 824-896MHZ 13DBD N FML
PC8210N 数据手册
Laird Technologies - Item # PC8210N, 800 MHz Models - ESMR, SMR, Cellular, GSM ... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > Vehicular Antennas & Telematics > Cellular Antennas > Dual Band & Special Applications Antennas > PCS/DCS and 2.4 GHz ISM band Yagi antennas > 800 MHz Models ESMR, SMR, Cellular, GSM and Conventional > Item # PC8210N Item # PC8210N, 800 MHz Models - ESMR, SMR, Cellular, GSM and Conventional For 800 MHz ESMR and SMR or conventional applications, choose 4 element PC804N, 6 element PC806N or ten element PC8010N. The Cushcraft PC804N, PC826N and PC8210N are also available in the 900 MHz GSM frequency band. larger image larger image Specifications Band GSM SMR ESMR Celluar Conventional Frequency 824 to 896 MHz Gain 11 dBD No. of Elements 10 Front to Back Ratio 20 dB 3dB Beamwidth, E Plane 40 º 3dB Beamwidth, H Plane 45 º http://lairdtech.thomasnet.com/printitem/cpe-antennas-wimax-3g-4g-lte-cellular-bwa-/-mhz-... 8/8/2012 Laird Technologies - Item # PC8210N, 800 MHz Models - ESMR, SMR, Cellular, GSM ... Page 2 of 2 RF Connector N (Female) Wind Surface Area 0.38 m2 0.035 ft2 Wind Survival 125 mph 200 kph W/ 1/2" Ice 100 mph 161 kph Length 46 in 116.8 cm Weight 2.37 lbs 1.07 kg Power 200 watts Element Material 1/4 in (0.63 cm) 6061T6 Aluminum Rod Boom Material 3/4 in (1.9 cm) 6061T6 Aluminum Channel Mounting Style U Bolt Max. Mast Diameter 2 1/8 in 5.4 cm Pigtail 19 in 48.3 cm http://lairdtech.thomasnet.com/printitem/cpe-antennas-wimax-3g-4g-lte-cellular-bwa-/-mhz-... 8/8/2012
PC8210N 价格&库存
很抱歉,暂时无法提供与“PC8210N”相匹配的价格&库存,您可以联系我们找货
