Laird Technologies - Item # SQ1855DD12NF, Squint™ Directional Antennas for Horizo... Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional
Antennas for Horizontal Mounting Surfaces > Item # SQ1855DD12NF
Item # SQ1855DD12NF, Squint™ Directional Antennas for Horizontal Mounting Surfaces
Cushcraft recently engineered a dual directional PCS band antenna for ceiling mount applications where directional
coverage at 180º and low visibility are desirable. The antenna exhibits 5 dBi of gain in the 1850-1990 MHz
frequency band. The antenna is 6” x 6” x 1 1/4” (15.2 x 15.2 x 3.2 cm) and weighs only 0.65 lbs. (0.3 kg). The
antenna housing is molded from UV stabile thermoplastic. Standard models are white in color with a textured finish.
Custom configurations of radome finish, color and texture can be provided to compliment and blend with any
environment. The antenna is a perfect choice to use with microcells, picocells and RF distribution systems where
directional coverage is desirable from a mounting location overhead. Applications for the array include hallways or
tunnels within industrial complexes, office complexes, shopping malls, parking garages, airports, hospitals and
campus settings and subway systems.
larger image
larger image
Specifications
Band
PCS
Frequency
1850 to 1990 MHz
VSWR
1:5:1
Polarization
Vertical Linear
Min. Gain
5 dBi
3dB Beamwidth, Azimuth Plane
70º Dual Directional
3dB Beamwidth, Elevation Plane
65 º
Cable Type
12' Plenum coax
Grounding
Element DC Grounded
RF Connector
Type N (Female)
http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/ectional-antennas-for-horizo...
8/8/2012
Laird Technologies - Item # SQ1855DD12NF, Squint™ Directional Antennas for Horizo... Page 2 of 2
Dimensions
6 x 6 x 1 1/4 in.
15.2 x 15.2 x 3.2 mm
Power
50 watts
Weight (With 12" Cable)
0.65 lbs
0.30 kg
Mounting Style
Ceiling
Surface
8/8/2012
很抱歉,暂时无法提供与“SQ1855DD12NF”相匹配的价格&库存,您可以联系我们找货
