S8242MP10NF
S8242MP10NF
    LAIRD(莱尔德)
    ANTENNA 824-896MHZ 2DBI N FML
S8242MP10NF 数据手册
Laird Technologies - Item # S8242MP10NF, 800 MHz Wall/Mast Mount Omnidirectiona... Page 1 of 1 Laird Technologies Web site: www.LairdTech.com All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni Antenna > SL80173WP Tri-Band Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > Item # S8242MP10NF Item # S8242MP10NF, 800 MHz Wall/Mast Mount Omnidirectional Antennas Designed to provide a very attractive alternative, the antenna exhibits 2 dBi of omnidirectional gain in the AMP, GSM or SMR frequency band in a very diminutive package (antenna measures only 4" x 3" x 1.5"). For wall mounting, best omnidirectional coverage is achieved by mounting to an interior wall surface backed by traditional wood frame studs. Antenna comes standard with coax pigtail and N female, SMA or TNC connector. larger image Specifications Band GSM AMP SMR Frequency 824 to 896 MHz Gain 2 dBi 3dB Beamwidth, E Plane 120 º 3dB Beamwidth, H Plane 110 º VSWR 2:1 Polarization Linear vertical Weight 0.4 lbs 0.18 kg RF Connector N (Female) Enclosure Material PVC Power 10 watts Mounting Style No Dimensions 4 x 3 x 1.5 in http://lairdtech.thomasnet.com/printitem/all-categories/800-mhz-wall-mast-mount-omnidire... 8/8/2012
S8242MP10NF 价格&库存
很抱歉,暂时无法提供与“S8242MP10NF”相匹配的价格&库存,您可以联系我们找货
