DCE-ANT5819-7X6X2
DCE-ANT5819-7X6X2
    LAIRD(莱尔德)
    ANT&ENCLOSURE 7X6X2 19DBI 8"
DCE-ANT5819-7X6X2 数据手册
7x6x2 DCE Die-Cast Enclosure Antennas e The DCE series die cast aluminum enclosures from Laird are designed for extremely long life in outdoor environments. The powder coat paint over aluminum construction offers unsurpassed resistance to corrosion. The pole mount hardware includes heavy galvanized pole clamps and stainless steel U bolts and attachment nuts. The die cast enclosure has extra heavy duty mounting flanges for reliable mounting to poles or surface mounting to walls. The most unique feature is the inclusion of 7 engineered hole knockouts which allow for many different configurations of connectors and feedthru’s without the need for drilling holes. The knockouts are easily removed using a flat blade screwdriver and hammer. The enclosures have Qty 4 threaded ¼” tall standoffs in the base for mounting a user plate (included), which in turn can hold the users electronics. This configuration provides universal mounting which is fully customizable by the user. FEATURES MARKETS • Die cast aluminum with white epoxy powder coat paint • Wireless base stations • Qty 7 engineered hole knockouts for many possible configurations. No drilling required! • Direct burial equipment • Qty 4 0.25” tall threaded standoffs and mounting plate for mounting of electronics inside enclosure • Pole mount or wall mount • IP67 rated for long term weatherproofing • Fits common WiFi radio boards Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com • Wireless client radios • Repeater systems • 802.11 a/b/g wireless systems • Fiber-optic junction box 7x6x2 DCE Die-Cast Enclosure Antennas ANTENNA PATTERNS 2300-2700 MHz H-Plane 2400-2500 MHz E-Plane H-Plane E-Plane H-Plane 3300-3800 MHz H-Plane E-Plane 5150-5850 MHz E-Plane VSWR GRAPHS 1.9 1.9 2.0 1.8 2.0 1.8 1.9 1.7 1.9 1.7 1.9 1.7 1.9 1.7 1.8 1.6 1.8 1.6 1.8 1.6 1.8 1.6 VSWR VSWR 1.5 1.3 1.5 1.3 1.4 1.2 1.4 1.2 1.3 1.1 1.3 1.1 1.3 1.1 1.3 1.1 1.2 1.0 1.2 1.0 1.2 1.0 1.2 1.0 2.302.30 2.342.34 2.382.38 2.422.42 2.462.46 2.50 2.50 2.542.54 2.582.58 2.622.62 2.662.66 2.702.70 1.1 1.1 Frequency Frequency (GHz)(GHz) 1.0 1.0 2. 400 2.400 1.1 1.1 2.302.30 2.342.34 2.382.38 2.422.42 2.462.46 2.502.50 2.542.54 2.582.58 2.622.62 2.662.66 2.702.70 2.0 2.0 Frequency Frequency (GHz)(GHz) 2.400 2.400 2.410 2.410 2.420 2.420 2.430 2.430 2.440 2.440 2.450 2.450 2.460 2.460 2.470 2.470 2.480 2.480 2.490 2.490 2.500 2.500 2.0 2.0 Frequency Frequency (GHz) (GHz) 1.9 1.9 1.9 1.9 3300-3800 MHz 2. 420 2.420 2. 430 2.430 1.9 1.9 1.7 1.7 1.9 1.9 1.7 1.7 1.8 1.8 1.6 1.6 1.8 1.8 1.6 1.6 2. 440 2.440 2. 450 2.450 2. 460 2.460 2. 470 2.470 2. 480 2.480 2. 490 2.490 2. 500 2.500 Frequency Hz) (G (GHz) Frequency 5150-5850 MHz VSWR 2.0 2.0 1.8 1.8 VSWR 2.0 2.0 1.8 1.8 1.7 1.7 1.5 1.5 2. 410 2.410 1.0 1.0 1.7 1.7 1.5 1.5 1.5 1.5 1.3 1.3 VSWR VSWR 1.6 1.6 1.4 1.4 VSWR 1.6 1.6 1.4 1.4 VSWR 1.6 1.4 1.6 1.4 1.4 1.2 1.2 1.4 VSWR VSWR 1.5 1.3 1.5 1.3 1.7 1.5 1.7 1.5 VSWR 1.7 1.5 1.5 1.7 VSWR VSWR 1.9 1.9 2.0 1.8 1.8 2.0 1.6 1.4 1.6 1.4 VSWR 2400-2500 MHz 2.0 2.0 VSWR VSWR 2300-2700 MHz 2.0 2.0 1.5 1.5 1.3 1.3 1.4 1.4 1.2 1.2 1.4 1.4 1.2 1.2 1.3 1.3 1.1 1.1 1.3 1.3 1.1 1.1 1.2 1.2 1.0 1.0 1.2 1.2 1.0 1.0 3.300 3.300 3.350 3.350 3.400 3.400 3.450 3.450 3.500 3.500 3.550 3.550 3.600 3.600 3.650 3.650 3.700 3.700 3.750 3.750 3.800 3.800 1.1 1.1 Frequency Frequency (GHz)(GHz) 1.0 1.0 5.150 5.150 5.220 5.220 5.290 5.290 5.360 5.360 5.430 5.430 5.500 5.500 5.570 5.570 5.640 5.640 5.710 5.710 5.780 5.780 5.850 5.850 1.11.1 Frequency Frequency (GHz)(GHz) 1.0 1.0 3.300 3.350 3.350 3.400 3.400 3.450 3.450 3.500 3.500 3.550 3.550 3.600 3.600 3.650 3.650 3.700 3.700 3.750 3.750 3.800 3.800 3.300 Frequency Frequency (GHz)(GHz) 5.150 5. 150 5.220 5. 220 5.290 5. 290 5.360 5. 360 5.430 5. 430 5.500 5. 500 5.570 5. 570 Frequency (GHz) Frequency Hz) (G 5.640 5. 640 5.710 5. 710 5.780 5. 780 5.850 5. 850 7x6x2 DCE Die-Cast Enclosure Antennas ications Gain (integrated antenna) VSWR (integrated antenna) Impedance Input Power Wind Survivability Weight (die-cast enclosure) Dimensions (inside) Dimensions (outside) Radome Operational Temperature Mount Style 2300-2700 2400-2500 14 dBi 1.8:1 12 dBi 1.5:1 3300-3800 4940-5850 16 dBi 18 dBi 1.7:1 1.7:1 50 OHM 100 W 150 mph 40 oz (1.13kg) 7.125” x 6.125” x 2” (181 x 156 x 51mm) 10" x 7.1"x 2.25" (254 x 180 x 57 mm) 2400-2485/ 5150-5850 12 / 15 dBi 1.5:1 ASA -30°C to +75°C Wall / Mast / Tilt Die Cast Enclosure (No Antenna) Die Cast Enclosure w/ Hinged Die Cast Door (No Antenna) Die Cast Enclosure w/ 2300-2700MHz, 14dBi Antenna Integrated Into Hinged Door Die Cast Enclosure w/ 2400-2500MHz, 12dBi Antenna Integrated Into Hinged Door Die Cast Enclosure w/ 3300-3800MHz, 16dBi Antenna Integrated Into Hinged Door Die Cast Enclosure w/ 4940-5850MHz, 19dBi Antenna Integrated Into Hinged Door Die Cast Enclosure w/ Dual-Band 2400-2485MHz/5150-5850MHz, 12dBi/16dBi Antenna Integrated Into Hinged Door (xxxx = connector type - MC, MMCX, RMMCX, RSMA, RTNC, SSMB, and UFL) ACCESSORIES FOR DCE-7x6x2 Hinged Die Cast Door for DCE-7x6x2 Hinged ASA Door w/2300-2700MHz, 14dBi Antenna Hinged ASA Door w/2400-2500MHz, 12dBi Antenna Hinged ASA Door w/3300-3800MHz, 16dBi Antenna Hinged ASA Door w/4940-5850MHz, 19dBi Antenna Hinged ASA Door w/Dual-Band 2400-2485MHz/5150-5850MHz, 12dBi/16dBi Antenna NOTES • All shipments F.O.B. Schaumburg, IL 60173 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com ANT-DS-7x6x2-DCE 0115 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
DCE-ANT5819-7X6X2
物料型号:DCE-ANT5819-xxxx, DCE-7x6x2, DCE-H-7x6x2, DCE-ANT2314-xxxx, DCE-ANT2412-xxxx, DCE-ANT3516-xxxx, DCE-ANT2451-xxxx
器件简介:这些外壳设计用于户外环境的超长寿命,采用粉末涂层铝制结构,具有卓越的耐腐蚀性。外壳有7个工程孔,无需钻孔即可配置多种连接器和穿透件。
引脚分配:文档中未明确提及引脚分配
参数特性:包括增益、VSWR、阻抗、输入功率、耐风性、重量、尺寸、雷达罩材料、工作温度范围和安装方式。
功能详解:文档提供了天线模式和VSWR图,展示了不同频率下的天线性能。
应用信息:适用于无线基站、无线客户端无线电、直埋设备、中继系统和802.11 a/b/g无线系统。
封装信息:外壳可以壁挂或杆挂安装,IP67等级,适合长期防水。
DCE-ANT5819-7X6X2 价格&库存
很抱歉,暂时无法提供与“DCE-ANT5819-7X6X2”相匹配的价格&库存,您可以联系我们找货
