33-2410-07
33-2410-07
    TALLYSMANWIRELESS
    TW2410天线采用了Tallysman独特的Accutenna技术,覆盖GPS L1、GLONASS G1频率带,以及SBAS(WAAS、QZSS、EGNOS & MSAS,1557MHz到1606...
33-2410-07 数据手册
TW2410/TW2412 TW2410 and TW2412 Single Band GNSS Antennas Frequency Coverage: L1/G1 Overview The TW2410 and TW2412 antennas employ Tallysman’s unique Accutenna technology, covering the GPS L1, GLONASS G1 frequency bands, as well as SBAS (WAAS, QZSS, EGNOS & MSAS, 1557MHz to 1606MHz). Designed for precision industrial, agricultural and military OEM applications the TW2410 and TW2412 provide a truly circular response over its entire bandwidth thereby producing superior multipath signal rejection. With a low axial ratio, excellent phase linear response and a tight phase centre variation, the TW2410 and TW2412 provide the performance normally associated with premium-priced antennas. Each antenna also features a dual-feed wideband patch element, with one Low Noise Amplifier (LNA) per feed, a mid section combiner and SAW filter, and a final output gain stage. Differing from the TW2410, only by an added pre-filter option, the TW2412 provides extra protection against saturation by strong near frequency or harmonic signals, such as LTE. The TW2410 and TW2412 are housed in a compact, industrial-grade weatherproof enclosure, and are available with a variety of connectors and cable lengths. They can be ordered with a choice of a magnet mount, adhesive mount, direct screw mount, or a plastic plug that provides a smooth mounting surface. Applications Features Benefits • High Accuracy & Mission Critical GNSS • Precision Agriculture, Mining & Construction • Military & Security • Avionics • Law Enforcement & Public Safety • Fleet Management & Asset Tracking • Great axial ratio: 1640 MHz >35 dB Gain ������������������������������������������� 28 dB min. Noise Figure ��������������������������� 1.5dB typ. Pre-filtered 50 dB 50 dB >1640 MHz >70 dB 28 dB min. 3.5dB typ. Gain Flatness ������������������������� +/- 2 dB VSWR �����������������������������������������
33-2410-07 价格&库存
很抱歉,暂时无法提供与“33-2410-07”相匹配的价格&库存,您可以联系我们找货
