DC24
Directional Antenna
1700 TO 2700 MHz DIRECTIONAL DIE CAST GRID ANTENNA SYSTEM
The DC24 is a directional antenna system, which incorporates a 2-piece aluminum die cast
parabolic grid type antenna reflector with a patented 50-ohm passive feed dipole. Installation is
simple with the Laird adjustable tilt “Heavy Duty” bracket that comes standard. The bracket
accommodates poles from 1 to 2.0 inches OD. Brackets are full galvanized for extreme corrosion
protection and each reflector comes complete with stainless steel hardware and complete
assembly instructions. The dipole feed assembly comes with a 30 inch LMR240 pigtail terminated
with an N male or N female connector. Other connector configurations are available upon request.
FEATURES
Small size/reduced shipping cost
30 in pigtail with N male or N female Connector
24 dBi antenna gain; horizontal or vertical polarity
Rugged, lightweight and waterproof
Heavy duty adjustable tilt bracket
2-Piece powder coat painted die cast aluminum
FREQUENCY
RANGE MODEL
MIN
PF-1
PF-2
2400
2100
SPECIFICATIONS
PARAMETER
MIN
Gain
Input Return Loss (S11)
VSWR
3 dB Beam Angle
Cross Pole
Front-to-Back
Side Lobe
Impedance
Input Power
Focal Length
Dimension (L x W)
Weight
Pole Diameter (OD)
Operating Temperature
Wind Loading 100 MPH
Wind Loading 140 MPH
MARKETS
2.4 GHz ISM band applications
Wireless internet access
Wireless bridges
Point-to-point repeaters
MMDS applications
Streaming video
WiMAX
TYP
TYP
MAX
UNITS
2483
2686
MHz
MHz
MAX
UNITS
24
-14
1.5:1
8
26
dBi
dB
24
50
16 (40.6)
42 x 24 (107 x 61)
5.5 (2)
1 (25)
-45
2 (50)
+70
80.5 (36.5)
126 (57)
deg
dB
dB
dB
ohm
w
in (cm)
in (cm)
lbs (kgs)
in (mm)
°C
lbs (kg)
lbs (kg)
SYSTEM ORDERING
DC24-HD-PF-xxxx-xx
Freq. Range
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.(0).1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
PF1 - PMPF-1 2.4 GHz ISM Band PF2
- PMPF-2 2.5 GHz MMDS Band
Feed Option
P - Pigtail with N Male connector PF Pigtail with N Female connector
ANT-DS-DC24 0911
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end
user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies
materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the
Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2011 Laird Technologies, Inc. All Rights Reserved. Laird, Laird
Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the
property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“DC24HDPF1P”相匹配的价格&库存,您可以联系我们找货
