DC24HDPF1PF-EZ
DC24HDPF1PF-EZ
    LAIRD(莱尔德)
    2.4GHz Dish RF Antenna 2.4GHz ~ 2.483GHz 24dBi Connector, N Female Bracket Mount
DC24HDPF1PF-EZ 数据手册
DC24 Directional Antenna 1700 TO 2700 MHz DIRECTIONAL DIE CAST GRID ANTENNA SYSTEM The DC24 is a directional antenna system, which incorporates a 2-piece aluminum die cast parabolic grid type antenna reflector with a patented 50-ohm passive feed dipole. Installation is simple with the Laird adjustable tilt “Heavy Duty” bracket that comes standard. The bracket accommodates poles from 1 to 2.0 inches OD. Brackets are full galvanized for extreme corrosion protection and each reflector comes complete with stainless steel hardware and complete assembly instructions. The dipole feed assembly comes with a 30 inch LMR240 pigtail terminated with an N male or N female connector. Other connector configurations are available upon request. FEATURES • • • • • • • Small size/reduced shipping cost 50-ohm passive feed dipole 30 in pigtail with N male or N female Connector 24 dBi antenna gain; horizontal or vertical polarity Rugged, lightweight and waterproof Heavy duty adjustable tilt bracket 2-Piece powder coat painted die cast aluminum FREQUENCY RANGE MODEL MIN PF-1 PF-2 2400 2100 SPECIFICATIONS PARAMETER MIN Gain Input Return Loss (S11) VSWR 3 dB Beam Angle Cross Pole Front-to-Back Side Lobe Impedance Input Power Focal Length Dimension (L x W) Weight Pole Diameter (OD) Operating Temperature Wind Loading 100 MPH Wind Loading 140 MPH MARKETS 2.4 GHz ISM band applications Wireless internet access Wireless bridges Point-to-point repeaters MMDS applications Streaming video WiMAX TYP TYP MAX UNITS 2483 2686 MHz MHz MAX UNITS 24 -14 1.5:1 8 26 dBi dB 24 50 16 (40.6) 42 x 24 (107 x 61) 5.5 (2) 1 (25) -45 2 (50) +70 80.5 (36.5) 126 (57) deg dB dB dB ohm w in (cm) in (cm) lbs (kgs) in (mm) °C lbs (kg) lbs (kg) SYSTEM ORDERING DC24-HD-PF-xxxx-xx Freq. Range Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.(0).1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com PF1 - PMPF-1 2.4 GHz ISM Band PF2 - PMPF-2 2.5 GHz MMDS Band Feed Option P - Pigtail with N Male connector PF Pigtail with N Female connector ANT-DS-DC24 0911 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2011 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
DC24HDPF1PF-EZ 价格&库存
很抱歉,暂时无法提供与“DC24HDPF1PF-EZ”相匹配的价格&库存,您可以联系我们找货
