S8803B
S8803B
    LAIRD(莱尔德)
    ANTENNA 880-960MHZ 5DBI N FML
S8803B 数据手册
Laird Technologies - Item # S8803B, 800/900 MHz. Omnidirectional Antennas for Data ... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Squint™ Dual-Band Ceiling Mount Antenna > Phantom Antennas > Squint™ Directional Antennas for Horizontal Mounting Surfaces > Squint™ ISM Ceiling/Surface Mount Dipole Antenna > 2 dBi Omnidirectional Ceiling Mount Antenna for PCS > Cellular 4 dBi Gain Ceiling Mount Panel Antenna > Dual band 800 MHz/1900 MHz, 900 MHz/1700 MHz 4 dBi Ceiling Omnidirectional Antenna > SL8025WP Tri-Band Omni Antenna > SL80173WP Tri-Band Omni Antenna > 800 MHz Wall/Mast Mount Omnidirectional Antennas > 800/900 MHz. Omnidirectional Antennas for Data Communications > Item # S8803B Item # S8803B, 800/900 MHz. Omnidirectional Antennas for Data Communications 800/900 MHz. Omnidirectional Antennas Omnidirectional antennas are the right choice for situations where you need to be in contact with sources that are in two directions or if you do not know what direction the signals will be coming from. Receiving signals from two wellheads that are in different directions is an example of the former. An example of the latter would be a warehouse environment where a worker with a handheld terminal is moving about the area while sending and receiving data. larger image Data Transmission Omnis Standard Data Transmission Omnis are fully decoupled antennas built on a copper laminate and housed in 0.100 inch wall fiberglass housings. They may be mounted right side-up or tipped upside down depending upon the desired pattern. They also feature a very versatile clamp mounting system that will fit most every situation you will encounter. Specifications Frequency 880 to 960 MHz Gain 3 dBD Nominal VSWR 1.5:1 Bandwidth 62 MHz 3dB Beamwidth, E Plane 45 º RF Connector N (Female) Height 30 3/4 in 78 cm Weight 1.19 lbs 0.53 kg Wind Surface Area 0.176 m2 0.016 ft2 http://lairdtech.thomasnet.com/printitem/all-categories/z-omnidirectional-antennas-for-data-... 8/8/2012 Laird Technologies - Item # S8803B, 800/900 MHz. Omnidirectional Antennas for Data ... Wind Survival 125 mph 200 kph Pigtail 23 cm Element Material Plated Copper Laminate Enclosure Material Fiberglass Mounting Style Tube end Max. Mast Diameter 2 in 5.1 cm Page 2 of 2 http://lairdtech.thomasnet.com/printitem/all-categories/z-omnidirectional-antennas-for-data-... 8/8/2012
S8803B 价格&库存
很抱歉,暂时无法提供与“S8803B”相匹配的价格&库存,您可以联系我们找货
