A Tallysman Accutenna®
TW3400/TW3402 GPS/GLONASS Antenna
The TW3400/TW3402 employs Tallysman’s unique
Accutenna technology covering the GPS L1, GLONASS
L1 and SBAS (WAAS, EGNOS & MSAS) frequency band
(1574 to 1606 MHz). They are especially designed for
precision industrial, agricultural and military
applications. . They provide truly circular response
over the antennas’ entire bandwidth thereby
producing superior multipath signal rejection.
The TW3400/TW3402 feature a highly circular dualfeed wideband patch element, with a two stage Low
Noise Amplifier, comprised of one input LNA per feed,
a mid section SAW to filter the combined output, and a
final output gain stage. This configuration provides
excellent axial ratio that is constant across the full
frequency band.
An optional tight pre-filter is
available on the TW3402 to protect against saturation
by high level sub-harmonic and L-Band signals.
TW3400 Dimensions (mm)
Flat radome is shown, Conical Radome also available
The TW3400/TW3402 is housed in a permanent
mount industrial grade weather-proof enclosure. Two
options for pole mounting are available an L-bracket
(P/N#23-0040-0) or a pipe mount (P/N#23-0065-0).
Applications
High Accuracy & Mission Critical Global Positioning
Precision Agriculture, Mining & Construction
Military & Security
Avionics
Law Enforcement & Public Safety
Fleet Management & Asset Tracking
Features
Great axial ratio: 1 dB typ.
Low noise LNA: 1 dB
High rejection SAW filter
High gain LNA: 26 dB typ.
Low current: 13 mA typ.
Wide voltage input range: 2.5 to 16 VDC
IP67 weather proof housing
Benefits
Excellent circular polarisation
Excellent multipath rejection
Excellent signal to noise ratio
Great out of band signal rejection
Increased system accuracy
Ideal for harsh environments
RoHS and REACH compliant
Specifications
Antenna
Architecture
1 dB Bandwidth
Antenna Gain (with 100mm ground plane)
Axial Ratio (over full bandwidth)
Dual, Quadrature Feeds
30 MHz
4.25 dBic
50dB (TW3402)
>25 dB
>50dB
>35 dB
>75dB
很抱歉,暂时无法提供与“33-3400-10-10-0200”相匹配的价格&库存,您可以联系我们找货
