RooTenna®
R2T24-19 High Gain Panel Antenna
Innovative Technology
for a Connected World
ROOTENNA® HIGH GAIN PANEL ANTENNA: 2400 TO 2700 MHz OPERATION
The RooTenna® high gain panel antenna offered by Laird Technologies is designed
to allow integration of the customer’s radio equipment inside the weatherproof
compartment. The radio compartment is big enough to house transceivers, amplifiers
and other electronic equipment. The antenna design utilizes a unique suspended wire
element over a solid backplane for more consistent performance over temperature and
humidity conditions. The housing is UV stabilized ABS plastic. The backplate is alodine
coated aluminium with stainless steel fasteners. All bracket fastners are stainless steel for
corrosion protection.
FEATURES
MARKETS
• RooTenna®, the antenna with a pouch!
• Integrated radio/antenna units
• Low profile 19dBi antenna gain
• WISP CPE equipment
• 16.25” x 14.75” x 1.25” weatherproof
radio compartment
• WiMAX applications
• 802.11b/g applications
• Low heat absorption white UV protected
housing
• Vertical or horizontal polarization,
beamwidth 15/20deg
• Available with RPSMA, RPTNC,
MC Card, MMCX, RPMMCX and U.FL
antenna connector
ANTENNA PATTERNS
-15
-30
30
-45
45
-60
60
75
-75
90
-90
105
-105
125
-125
135
-135
150
-150
-165
165
180
2.45 GHz
global solutions: local support
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +1.32.80.7866.12
IAS-EUSales@lairdtech.com
Asia: +1.65.6.243.8022
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
TM
RooTenna®
SPECIFICATIONS
PARAMETER
MIN
TYP
Frequency Range
2400
MAX
UNITS
2700
MHz
Gain
19
dBi
3db Beam Angle (E-Plane)
19
Deg
3db Beam Angle (H-Plane)
16
Deg
Front to Back
30
dB
VSWR
1.5:1
Impedance
50
OHM
Input Power
Operating Temperature
-45
Weight
50
W
+70
Deg C
6 (2.7)
Compartment Dimension
(L x W x H)
Outside Dim
(L x W x H)
oz (kg)
(413 x 375 x 32)
18.5” x 16.8” x 2.5”
(470 x 427 x 64)
in (mm)
in (mm)
WIND LOADING
Force (Lbs)
100 MPH
125 MPH
100 MPH WITH ½“ RADIAL ICE
77.8
121
83
SYSTEM ORDERING INFORMATION
R2T24-19-XXXX
2400-2700MHz 19dBi high gain RooTenna® compartment antenna
(XXXX= connector type. Please specify RSMA, RTNC, MMCX, RMMCX, MC or UFL when ordering)
NOTES
• All shipments F.O.B. Schaumburg, IL 60173
ANT-DS-R2T24-19 0809
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for
the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies
makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be
liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from
time to time, a copy of which will be furnished upon request. © Copyright 2009 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo,
and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“R2T24-19-MMCX”相匹配的价格&库存,您可以联系我们找货
