R2T24-19-UFL
R2T24-19-UFL
    LAIRD(莱尔德)
    ANT ROOTENNA 19DBI RJ45 8" U.FL
R2T24-19-UFL 数据手册
RooTenna® R2T24-19 High Gain Panel Antenna Innovative Technology for a Connected World ROOTENNA® HIGH GAIN PANEL ANTENNA: 2400 TO 2700 MHz OPERATION The RooTenna® high gain panel antenna offered by Laird Technologies is designed to allow integration of the customer’s radio equipment inside the weatherproof compartment. The radio compartment is big enough to house transceivers, amplifiers and other electronic equipment. The antenna design utilizes a unique suspended wire element over a solid backplane for more consistent performance over temperature and humidity conditions. The housing is UV stabilized ABS plastic. The backplate is alodine coated aluminium with stainless steel fasteners. All bracket fastners are stainless steel for corrosion protection. FEATURES MARKETS • RooTenna®, the antenna with a pouch! • Integrated radio/antenna units • Low profile 19dBi antenna gain • WISP CPE equipment • 16.25” x 14.75” x 1.25” weatherproof radio compartment • WiMAX applications • 802.11b/g applications • Low heat absorption white UV protected housing • Vertical or horizontal polarization, beamwidth 15/20deg • Available with RPSMA, RPTNC, MC Card, MMCX, RPMMCX and U.FL antenna connector ANTENNA PATTERNS -15 0 15 -30 30 -45 45 -60 60 75 -75 90 -90 105 -105 125 -125 135 -135 150 -150 -165 165 180 2.45 GHz global solutions: local support Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +1.32.80.7866.12 IAS-EUSales@lairdtech.com Asia: +1.65.6.243.8022 IAS-AsiaSales@lairdtech.com www.lairdtech.com TM RooTenna® R2T24-19 High Gain Panel Antenna Innovative Technology for a Connected World SPECIFICATIONS PARAMETER MIN TYP Frequency Range 2400 MAX UNITS 2700 MHz Gain 19 dBi 3db Beam Angle (E-Plane) 19 Deg 3db Beam Angle (H-Plane) 16 Deg Front to Back 30 dB VSWR 1.5:1 Impedance 50 OHM Input Power Operating Temperature -45 Weight 50 W +70 Deg C 6 (2.7) Compartment Dimension (L x W x H) Outside Dim (L x W x H) oz (kg) 16.25” x 14.75” x 1.25” (413 x 375 x 32) 18.5” x 16.8” x 2.5” (470 x 427 x 64) in (mm) in (mm) WIND LOADING Force (Lbs) 100 MPH 125 MPH 100 MPH WITH ½“ RADIAL ICE 77.8 121 83 SYSTEM ORDERING INFORMATION R2T24-19-XXXX 2400-2700MHz 19dBi high gain RooTenna® compartment antenna (XXXX= connector type. Please specify RSMA, RTNC, MMCX, RMMCX, MC or UFL when ordering) NOTES • All shipments F.O.B. Schaumburg, IL 60173 ANT-DS-R2T24-19 0809 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2009 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
R2T24-19-UFL 价格&库存
很抱歉,暂时无法提供与“R2T24-19-UFL”相匹配的价格&库存,您可以联系我们找货
