R2T58-24-RSMA
R2T58-24-RSMA
    LAIRD(莱尔德)
    ANT ROOTENNA 24DBI 8" RSMA
R2T58-24-RSMA 数据手册
R2T58-24 global solutions : local support TM RooTenna® 2 Panel Antenna Features and Benefits: 4940 to 5850 MHz Operation • RooTenna®, the antenna with a pouch! The RooTenna® panel antenna offered by Laird Technologies is designed to allow integration of the customers’ radio equipment inside the weatherproof compartment. The radio compartment is big enough to house transceivers, amplifiers, and other electronic equipment.The unit is complete with a removable customer mounting plate for mounting of customer electronics and an RJ45 passthru ethernet feedthru.. The housing is UV stabilized ABS plastic. The backplate is alodine coated aluminum with stainless steel fasteners. All bracket fasteners are stainless steel for corrosion protection. • Low profile 24dBi antenna gain • 16.25" x 14.75" x 1.25" weatherproof radio compartment • Low heat absorption white UV protected housing • Vertical or horizontal polarization, Beamwidth 9deg • Available with RPSMA, RPTNC, MC Card, MMCX, RPMMCX and U.FL antenna connector Applications • Integrated radio/antenna units • WISP CPE equipment • Amplified antennas • 802.11a applications For sales information: Telephone 800-323-3757 E-Mail sales@pacwireless.com or visit: www.pacwireless.com www.pacwireless.com R2T58-24 ljlj Specifications Antenna Pattern at 5850 MHz Parameter Min Frequency Range 4940 Typ 5850 VSWR (4940-4990MHz
R2T58-24-RSMA 价格&库存
很抱歉,暂时无法提供与“R2T58-24-RSMA”相匹配的价格&库存,您可以联系我们找货
