33-2710-02-0300
33-2710-02-0300
    TALLYSMANWIRELESS
    TW2710 和 TW2712 天线采用了 Tallysman 的独特 Accutenna 技术,覆盖 GPS L1、GLONASS G1、BeiDou B1、Galileo E1 频段,以及 SBA...
33-2710-02-0300 数据手册
TW2710/TW2712 TW2710 and TW2712 Single Band GNSS Antennas Frequency Coverage: L1/G1/B1/E1 Overview The TW2710 and TW2712 antennas employ Tallysman’s unique Accutenna technology, covering the GPS L1, GLONASS G1, BeiDou B1, Galileo E1, frequency bands, as well as SBAS (WAAS, QZSS, EGNOS & MSAS, 1557MHz to 1606MHz). Designed for precision industrial, agricultural and military applications the TW2710 and TW2712 provide a truly circular response over its entire bandwidth thereby producing superior multipath signal rejection. With a low axial ratio, excellent phase linear response and a tight phase centre variation, the TW2710 and TW2712 provide the performance normally associated with premium-priced antennas. Each antenna also features a dual-feed wideband patch element, with one Low Noise Amplifier (LNA) per feed, a mid section combiner and SAW filter, and a final output gain stage. Differing from the TW2710, only by an added pre-filter option, the TW2712 provides extra protection against saturation by strong near frequency or harmonic signals, such as LTE. The TW2710 and TW2712 are housed in a compact, industrial-grade weatherproof enclosure, and are available with a variety of connectors and cable lengths. They can be ordered with a choice of a magnet mount, adhesive mount, direct screw mount, or a plastic plug that provides a smooth mounting surface. Applications Features Benefits • High Accuracy & Mission Critical GNSS • Precision Agriculture, Mining & Construction • Military & Security • Law Enforcement & Public Safety • Fleet Management & Asset Tracking • Covers B1 / E1 /L1 / G1 Frequencies • Great axial ratio: 1 typ., 3 dB max • Low noise LNA: ≤1 dB • High rejection SAW filter • LNA gain: 28 dB typ. • Low current: 15 mA typ. • Wide voltage input range: 2.5 to 16 VDC • Excellent multipath rejection • Increased system accuracy • Excellent signal to noise ratio • Great out of band signal rejection • Ideal for harsh environments • RoHS compliant About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission is to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at competitive prices. Learn more at www.tallysman.com Contact us: info@tallysman.com T: +1 613 591-3131 TW2710 and TW2712 Single Band GNSS Antennas Frequency Coverage: L1/G1/B1/E1 Antenna (Measured on a 100mm Ground Plane) Low Noise Amplifier (LNA) Architecture ������������������������� Dual-feed RHCP ceramic patch Gain Axial Ratio dBic typ. at Zenith dB at Zenith L1 4.75 ≤ 2 typ. 2.5 max. L2 - - L5 - - G1 4.75 ≤ 2 typ. 2.5 max. G2 - - G3 - - GNSS GPS GLONASS Galileo BeiDou (Measured a Vcc = 3V, Temperature=25°C) Frequency Bandwidth ������ 1559-1606 MHz E1 4.75 ≤ 2 typ. 2.5 max. E5a - - E5b - - E6 - - B1 4.75 ≤ 2 typ. 2.5 max. B2 - - B3 - - IRNSS/NavIC L5 - - QZSS L6 - - Iridium - - Globalstar - - TW2710 TW2712 Architecture No pre-filter Out-of-Band Rejection 40 dB 20 dB >1640 MHz >45 dB Gain ������������������������������������������� 28 dB min. Noise Figure ��������������������������� 1.5 dB typ. Pre-filtered 60 dB 45 dB >1640 MHz >45 dB 26 dB min. 3.5 dB typ. Gain Flatness ������������������������� +/- 2 dB VSWR �����������������������������������������
33-2710-02-0300 价格&库存
很抱歉,暂时无法提供与“33-2710-02-0300”相匹配的价格&库存,您可以联系我们找货
