TW2710/TW2712
TW2710 and TW2712 Single Band GNSS Antennas
Frequency Coverage: L1/G1/B1/E1
Overview
The TW2710 and TW2712 antennas employ Tallysman’s
unique Accutenna technology, covering the GPS L1,
GLONASS G1, BeiDou B1, Galileo E1, frequency bands,
as well as SBAS (WAAS, QZSS, EGNOS & MSAS, 1557MHz
to 1606MHz).
Designed for precision industrial, agricultural and
military applications the TW2710 and TW2712 provide a
truly circular response over its entire bandwidth thereby
producing superior multipath signal rejection.
With a low axial ratio, excellent phase linear response
and a tight phase centre variation, the TW2710 and
TW2712 provide the performance normally associated
with premium-priced antennas.
Each antenna also features a dual-feed wideband patch
element, with one Low Noise Amplifier (LNA) per feed, a
mid section combiner and SAW filter, and a final output
gain stage.
Differing from the TW2710, only by an added pre-filter
option, the TW2712 provides extra protection against
saturation by strong near frequency or harmonic
signals, such as LTE.
The TW2710 and TW2712 are housed in a compact,
industrial-grade weatherproof enclosure, and are
available with a variety of connectors and cable lengths.
They can be ordered with a choice of a magnet mount,
adhesive mount, direct screw mount, or a plastic plug
that provides a smooth mounting surface.
Applications
Features
Benefits
• High Accuracy & Mission Critical GNSS
• Precision Agriculture, Mining &
Construction
• Military & Security
• Law Enforcement & Public Safety
• Fleet Management & Asset Tracking
• Covers B1 / E1 /L1 / G1 Frequencies
• Great axial ratio: 1 typ., 3 dB max
• Low noise LNA: ≤1 dB
• High rejection SAW filter
• LNA gain: 28 dB typ.
• Low current: 15 mA typ.
• Wide voltage input range: 2.5 to 16 VDC
• Excellent multipath rejection
• Increased system accuracy
• Excellent signal to noise ratio
• Great out of band signal rejection
• Ideal for harsh environments
• RoHS compliant
About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading
manufacturer of high-precision antennas and components for Global Navigation Satellite System (GNSS)
applications. Tallysman’s mission is to support the needs of a new generation of positioning systems by
delivering unprecedented antenna precision at competitive prices. Learn more at www.tallysman.com
Contact us:
info@tallysman.com
T: +1 613 591-3131
Antenna (Measured on a 100mm Ground Plane)
Architecture ������������������������� Dual-feed RHCP ceramic patch
Gain
Axial Ratio
dBic typ. at Zenith
dB at Zenith
L1
4.75
≤ 2 typ. 2.5 max.
L2
L5
G1
4.75
≤ 2 typ. 2.5 max.
G2
G3
GNSS
GPS
GLONASS
Galileo
BeiDou
(Measured a Vcc = 3V, Temperature=25°C)
Frequency Bandwidth ������ 1559-1606 MHz
E1
4.75
≤ 2 typ. 2.5 max.
E5a
E5b
E6
B1
4.75
≤ 2 typ. 2.5 max.
B2
B3
IRNSS/NavIC
L5
QZSS
L6
Iridium
Globalstar
TW2710 TW2712
Architecture
No pre-filter
Out-of-Band Rejection
40 dB
20 dB
>1640 MHz >45 dB
Gain ������������������������������������������� 28 dB min.
Noise Figure ��������������������������� 1.5 dB typ.
Pre-filtered
60 dB
45 dB
>1640 MHz >45 dB
26 dB min.
3.5 dB typ.
Gain Flatness ������������������������� +/- 2 dB
VSWR �����������������������������������������
很抱歉,暂时无法提供与“33-2710-07-0000”相匹配的价格&库存,您可以联系我们找货
