CAF94579(IGO2450-NF12)
    LAIRD(莱尔德)
    ANT OMNID 5DBI 12" RG-142 N FEM
CAF94579(IGO2450-NF12) 数据手册
Model Number: 2.4 GHz MegaSphere – Outdoor/Indoor IGO2450 Omnidirectional In-Building Antenna Specifications: Weather resistant and waterproof with fully sealed radome. Installed vertically with cable exiting “top” or “bottom” Element Type Linear Array Frequency Range 2.4 – 2.5 GHz Peak Gain 5 dBi Polarization Vertical Impedance 50 ohms Maximum Input Power 50 watts VSWR (Min. Performance) < 2.0:1 Dimensions 28.5 x 3.2 cm Housing PVC Wind Resistance 120 mph Operating/Storage Temperature -40º to +70ºC Back Mounting: Outdoor kit: adjustable pole clamp & spacer Indoor kit: beam-clip, ceiling grid clip & optional-use ceiling stand-off Cables & Connectors: Model # IGO2450-RT12 IGO2450-NF12 Reference # CAF94568 CAF94579 Plenum Rated Coax 12" RG-142 12" RG-142 Connector RP-TNC N-Female Pattern data files for LANPlanner are available at www.centurion.com or www.wirelessvalley.com. Indoor Mounting Kit Azimuth Plane Cut perpendicular to the antenna and perpendicular to the cable Elevation Plane Cut perpendicular to the antenna along the cable axis Specifications subject to change without notice. 3425 N.44th Street, LINCOLN, NE 68504 USA PHONE: 402.467.4491 • FAX: 402.467.4528 TECHNICAL SUPPORT: 888.454.6914 www.centurion.com • sales@centurion.com Copyright  2004 Centurion Wireless Technologies, Inc. All Rights Reserved Outdoor Mounting Kit IGO2450a – 4/30/04
CAF94579(IGO2450-NF12) 价格&库存
很抱歉,暂时无法提供与“CAF94579(IGO2450-NF12)”相匹配的价格&库存,您可以联系我们找货
