VLQ24593BN4N-518B
VLQ24593BN4N-518B
    LAIRD(莱尔德)
    ANTMIMOWI-FI4XRPSMAMALEBK
VLQ24593BN4N-518B 数据手册
Vehicular 4-Port MIMO Antenna VLQ24593xN4N 2400-2500 MHz / 4900-5925 MHz The Laird vehicular 4-port MIMO Wi-Fi disk puck antenna covers the 2400-2500 MHz / 4900-5925 MHz bands. The VLQ24593xN4N is configured with 4-port, dual-band elements. The four (4) WiFi ports have RP-SMA male cable plug connectors. The housing incorporates a low-profile, rugged design that meets IP67 standards. The antenna also features high impact, UV-resistant polycarbonate plastic available in black or white. SPECIFICATIONS PARAMETER Model Number PERFORMANCE VLQ24593BN4N-518B (Black) VLQ24593WN4N-518B (White) 4-ports (WiFi) No. of Ports Frequency Bands (MHz) 2400-2500 MHz 4900-5925 MHz Peak Gain * dBi 2.2 3.5 Max Gain +/- 30o above horizon VSWR** Typical N/A 3.5 < 1.4:1 < 1.4:1 VSWR** Max < 2.0:1 < 2.0:1 Typical Port-to-Port Isolation ** 2400-2500 MHz 4900-5925 MHz Port 1-to-Port 2 > 23 dB > 28 dB Port 1-to-Port 3 > 20 dB > 26 dB Port 1-to-Port 4 > 20 dB > 26 dB Port 2-to-Port 3 > 25 dB > 26 dB Port 2-to-Port 4 > 21 dB > 26 dB > 21 dB > 20 dB > 26 dB Port 3-to-Port 4 Port-to-Port Isolation **, Max Nominal Impedance 50 Ω Polarization Azimuth Beam Width Input Power, Max > 28 dB Vertical Linear Omnidirectional 10 Watt per port (ambient temp. of 25°C / 77°F) Operating Temperature Storage Temperature Dimensions (dia. x hgt.) Weight Connector -35°C to +75°C (-31°F to +167°F) -35°C to +80°C (-31°F to +176°F) 127 mm x 38.5 mm (5.0" x 1.52") Approximately 0.91 kg (2.01 lbs) 4 x RP-SMA-Male Cable Plug Cable (exposed length) LMR195M- 518.2 cm (17 ft) Radome / Baseplate Material PC, UL94 - V0 Rating, UV Stable Material Compliance ROHS compliant IP67 IP Dust & Water Ingress Rating * Measured on 1 ft. (30.48 cm) diameter ground plane ** Measured with 17 ft. (518 cm) cable PART NUMBERS PART NUMBER Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com VLQ24593BN4N-518B 4-Ports WiFi VLQ24593WN4N-518B 4-Ports WiFi 4x RP-SMA Male 4x RP-SMA Male (Black) (White) Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Vehicular 4-Port MIMO Antenna VLQ24593xN4N RADIATION PATTERNS 2400 MHz 2440 MHz 2500 MHz 4900 MHz 5400 MHz 5925 MHz ANT-DS-VLQ24593xN4N 0915 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
VLQ24593BN4N-518B 价格&库存
很抱歉,暂时无法提供与“VLQ24593BN4N-518B”相匹配的价格&库存,您可以联系我们找货
