GPSD4103P
GPSD4103P
    LAIRD(莱尔德)
    ANTGPSAVLDBSV410-425MHZ
GPSD4103P 数据手册
Phantom Low Profile Dual Band UHF / GPS, Roof Mount Antenna GPSD4503P PHANTOM ANTENNA IS IDEAL FOR DUAL BAND UHF / GPS MOBILE APPLICATIONS Laird's unique Phantom dual band UHF / GPS antenna is designed for heavy duty, high performance applications and operates at maximum effectiveness when mounted on a 10” diameter (min.) ground plane surface. A threaded permanent stud mount provides vandal resistant vehicle mounting. The Phantom can also permanently mount to brackets, panels or any other kind of housing with proper ground plane surface. FEATURES APPLICATIONS • High performance mobile antenna operates on a 10” diameter (min.) ground plane. • Commercial & Industrial • Designs cover low profile to pure performance mobile applications. • Easy installation w/ Roof mount on permanent installed. • 100% tested on a network analyzer SPECIFICATIONS ELECTRICAL Frequency Range 450 - 470 MHz VSWR < 2:1 Peak Gain 3 dBi Maximum Power 100 W Nominal Impedance 50 Ohm Polarization Vertical Pattern Omni-directional Half-Power Beamwidth 146° x 360° typical Cable Length 17ft of RG58A/U / 17ft of RG174/U Termination N-male (Radio) / SMB Plug (GPS) MECHANICAL Color Black or White Height 3.5" Dimensions (Ht. x dia.) Operating Temperature 3" at base ABS MODEL AND ORDERING INFORMATION MODEL DESCRIPTION CONNECTORS N-male Installed GPSD4103P Dual Band Phantom 410-425 MHz & GPS, Roof Mount GPSD4503P Dual Band Phantom 450-470 MHz & GPS, Roof Mount N-male Installed GPSD4903P Dual Band Phantom 490-512 MHz & GPS, Roof Mount N-male Installed GPS16412 Dual Band Phantom 410-425 MHz & GPS, Roof Mount BNC male not installed Americas: +1.847 839.6907  IAS‐AmericasEastSales@lairdtech.com  Europe: +44.1628.858941  IAS‐EUSales@lairdtech.com  Asia:  +86.21.5855.0827.127  IAS‐AsiaSales@lairdtech.com  www.lairdtech.com  ANT-DS-TRA6927M3xxN 0615 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
GPSD4103P
物料型号: - GPSD4103P:双频段Phantom 410-425 MHz & GPS,车顶安装 - GPSD4503P:双频段Phantom 450-470 MHz & GPS,车顶安装 - GPSD4903P:双频段Phantom 490-512 MHz & GPS,车顶安装 - GPS16412:双频段Phantom 410-425 MHz & GPS,车顶安装,BNC公头未安装
器件简介: Phantom天线专为双频段UHF/GPS移动应用设计,适用于重型、高性能应用。当安装在直径至少为10英寸的接地平面表面上时,效果最佳。
引脚分配: - N型公头(无线电) - SMB插头(GPS)
参数特性: - 频率范围:450-470 MHz - 电压驻波比(VSWR):<2:1 - 峰值增益:3dBi - 最大功率:100W - 标称阻抗:50欧姆 - 极化:垂直 - 模式:全向 - 半功率波束宽度:146°x360°(典型值) - 电缆长度:17英尺RG58A/U / 17英尺RG174/U - 端接:N型公头(无线电)/ SMB插头(GPS)
功能详解: Phantom天线设计用于从低剖面到纯性能移动应用。易于安装,车顶永久安装。在网络分析仪上100%测试。
应用信息: 适用于商业和工业的高性能移动天线,操作在直径至少为10英寸的接地平面上。
封装信息: - 颜色:黑色或白色 - 高度:3.5英寸 - 尺寸(高x直径):底部3英寸 - 工作温度:ABS
GPSD4103P 价格&库存
很抱歉,暂时无法提供与“GPSD4103P”相匹配的价格&库存,您可以联系我们找货
