10x10x2 DCE
Die-Cast Enclosure Antennas
10X10 DCE OFFERS 900 TO 5850 MHZ OPERATION OPTIONS
The DCE series die cast aluminum enclosures from Laird are an innovative antenna system which
gives the operator ultimate system flexibility. The die-cast enclosure is available as a stand-alone
enclosure, with an integrated low-gain antenna, or with a detachable high-gain panel antenna.
Antennas are wide band for spectral flexibility.
Radomes are UV resistant ASA plastic. Hardware is stainless steel. The antenna systems come
with a pigtail cable with choice of connectors to adapt to any available radio equipment. There is
a removable and customizable user mounting plate inside for mounting electronics. The antenna
models come standard with Laird Technologies patented RJ45-ECS field replaceable ethernet
connector feedthru.
The die-cast enclosure can be pole or wall mounted. A heavy duty tilt bracket is available
for those installations requiring up or downtilt. Eleven (11) engineered knockouts are provided; 9
sized for N connectors and 2 sized for a cable feedthru.
FEATURES
MARKETS
• 11 engineered knockouts
• WiFi / WLAN / WiMAX systems
• Wide band antennas
• Industrial wireless
• Rugged and weatherproof
• Mesh networks
• Hinged cover for easy maintenance
• Wi-POP base stations
• IP 67 Rated
• Client antennas
• Integrated low gain or detachable high gain
antenna in variety of frequencies and gains
• Industrial wet process
electrical enclosure
SPECIfICATIONS
900-928
2400-2700
4900-5850
Gain (integrated antenna)
8dBi
15dBi
19dBi
Gain (detachable antenna)
VSWR (integrated antenna)
VSWR (detachable antenna)
Impedance
Input Power
Wind Survivability
Weight (die-cast enclosure)
Weight (detachable antenna)
Dimensions (inside)
Dimensions (outside integrated antenna)
Dimensions (outside detachable antenna)
Dimensions (stand alone DCE enclosers)
Radome
Operational Temperature
Mount Style
12dBi
1.5:1
1.5:1
19dBi
1.5:1
1.5:1
24dBi
1.7:1
1.5:1
2400-2485/
5150-5850
12dBi at 2.4GHz,
16dBi at 5.15GHz
N/A
2:1
N/A
50 OHM
100 W
Die-cast enclosure (150mph); Detachable antenna (125mph)
5.3lb (2.4kg)
3lb (1.4kg)
254 x 254 x 51 mm (10” x 10” x 2”)
317 x 264 x 99 mm (12.5” x 10.4”x 3.9”)
410 x 371 x 32 mm (16.13” x 14.63” x 1.3”)
317.5 x 264.16 x 76.2 mm (12.5” X 10.4” X 3”)
ASA
-30°C to +75°C
Wall / Mast / Tilt
systEM orDErinG inForMation
DCE10D-912-Nf
Die Cast Enclosure with detachable 900-928MHz 12dBi panel antenna
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
DCE10D-2419-Nf
DCE10D-4924-Nf
Die Cast Enclosure with detachable 2400-2700MHz 19dBi panel antenna
Die Cast Enclosure with detachable 4940-5850MHz 24dBi panel antenna
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
DCE10l-985-xxxx
Die Cast Enclosure with integrated 900-928MHz 8dBi panel antenna
DCE10l-2416-xxxx
Die Cast Enclosure with integrated 2400-2700Mhz 16dBi antenna
DCE10l-4919-xxxx
DCE10I-2451-xxxx
Die Cast Enclosure with integrated 4940-5850Mhz 19dBi antenna
Die Cast Enclosure with integrated 2400-2485MHz and 4900-5850MHz 16dBi antenna
DCE10-H-001
Hinged die-cast enclosure only
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
(xxxx = connector type - Nf, SfMf, RSMM, MCM, MMCXP, RTNM, RMMXP, SSMB and UfL)
10x10x2 DCE
Antenna Patterns
Integrated 10x10 902-928 MHz
H-Plane
E-Plane
Integrated 10x10 2.4-2.7 GHz
H-Plane
E-Plane
Integrated 10x10 4.9-5.875 GHz
H-Plane
Dual Band Patterns
2400-2485 MHz
E-Plane
Detachable 14x16 902-928 MHz
H-Plane
E-Plane
Detachable 14x16 2.4-2.7 GHz
H-Plane
E-Plane
Detachable 14x16 4.9-5.85 GHz
H-Plane
E-Plane
5150-5850 MHz
ANT-DS-10x10-DCE 09115
Any information furnished by Laird, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird
products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird, Inc. All Rights
Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product
or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“DCE10I-4919-UFL”相匹配的价格&库存,您可以联系我们找货
