DCE10I-2416-RTNM
DCE10I-2416-RTNM
    LAIRD(莱尔德)
    ANT&ENCL PNL 2.5GHZ 16DBI 8"RTNM
DCE10I-2416-RTNM 数据手册
10x10x2 DCE Die-Cast Enclosure Antennas 10X10 DCE OFFERS 900 TO 5850 MHZ OPERATION OPTIONS The DCE series die cast aluminum enclosures from Laird are an innovative antenna system which gives the operator ultimate system flexibility. The die-cast enclosure is available as a stand-alone enclosure, with an integrated low-gain antenna, or with a detachable high-gain panel antenna. Antennas are wide band for spectral flexibility. Radomes are UV resistant ASA plastic. Hardware is stainless steel. The antenna systems come with a pigtail cable with choice of connectors to adapt to any available radio equipment. There is a removable and customizable user mounting plate inside for mounting electronics. The antenna models come standard with Laird Technologies patented RJ45-ECS field replaceable ethernet connector feedthru. The die-cast enclosure can be pole or wall mounted. A heavy duty tilt bracket is available for those installations requiring up or downtilt. Eleven (11) engineered knockouts are provided; 9 sized for N connectors and 2 sized for a cable feedthru. FEATURES MARKETS • 11 engineered knockouts • WiFi / WLAN / WiMAX systems • Wide band antennas • Industrial wireless • Rugged and weatherproof • Mesh networks • Hinged cover for easy maintenance • Wi-POP base stations • IP 67 Rated • Client antennas • Integrated low gain or detachable high gain antenna in variety of frequencies and gains • Industrial wet process electrical enclosure SPECIfICATIONS 900-928 2400-2700 4900-5850 Gain (integrated antenna) 8dBi 15dBi 19dBi Gain (detachable antenna) VSWR (integrated antenna) VSWR (detachable antenna) Impedance Input Power Wind Survivability Weight (die-cast enclosure) Weight (detachable antenna) Dimensions (inside) Dimensions (outside integrated antenna) Dimensions (outside detachable antenna) Dimensions (stand alone DCE enclosers) Radome Operational Temperature Mount Style 12dBi 1.5:1 1.5:1 19dBi 1.5:1 1.5:1 24dBi 1.7:1 1.5:1 2400-2485/ 5150-5850 12dBi at 2.4GHz, 16dBi at 5.15GHz N/A 2:1 N/A 50 OHM 100 W Die-cast enclosure (150mph); Detachable antenna (125mph) 5.3lb (2.4kg) 3lb (1.4kg) 254 x 254 x 51 mm (10” x 10” x 2”) 317 x 264 x 99 mm (12.5” x 10.4”x 3.9”) 410 x 371 x 32 mm (16.13” x 14.63” x 1.3”) 317.5 x 264.16 x 76.2 mm (12.5” X 10.4” X 3”) ASA -30°C to +75°C Wall / Mast / Tilt systEM orDErinG inForMation DCE10D-912-Nf Die Cast Enclosure with detachable 900-928MHz 12dBi panel antenna Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com DCE10D-2419-Nf DCE10D-4924-Nf Die Cast Enclosure with detachable 2400-2700MHz 19dBi panel antenna Die Cast Enclosure with detachable 4940-5850MHz 24dBi panel antenna Europe: +44.1628.858941 IAS-EUSales@lairdtech.com DCE10l-985-xxxx Die Cast Enclosure with integrated 900-928MHz 8dBi panel antenna DCE10l-2416-xxxx Die Cast Enclosure with integrated 2400-2700Mhz 16dBi antenna DCE10l-4919-xxxx DCE10I-2451-xxxx Die Cast Enclosure with integrated 4940-5850Mhz 19dBi antenna Die Cast Enclosure with integrated 2400-2485MHz and 4900-5850MHz 16dBi antenna DCE10-H-001 Hinged die-cast enclosure only Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com (xxxx = connector type - Nf, SfMf, RSMM, MCM, MMCXP, RTNM, RMMXP, SSMB and UfL) 10x10x2 DCE Die-Cast Enclosure Antennas Antenna Patterns Integrated 10x10 902-928 MHz H-Plane E-Plane Integrated 10x10 2.4-2.7 GHz H-Plane E-Plane Integrated 10x10 4.9-5.875 GHz H-Plane Dual Band Patterns 2400-2485 MHz E-Plane Detachable 14x16 902-928 MHz H-Plane E-Plane Detachable 14x16 2.4-2.7 GHz H-Plane E-Plane Detachable 14x16 4.9-5.85 GHz H-Plane E-Plane 5150-5850 MHz ANT-DS-10x10-DCE 09115 Any information furnished by Laird, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
DCE10I-2416-RTNM
物料型号: - DCE10D-912-Nf:带有可拆卸的900-928MHz 12dBi面板天线的压铸外壳 - DCE10D-2419-Nf:带有可拆卸的2400-2700MHz 19dBi面板天线的压铸外壳 - DCE10D-4924-Nf:带有可拆卸的4940-5850MHz 24dBi面板天线的压铸外壳 - DCE10l-985-xxxx:带有集成的900-928MHz 8dBi面板天线的压铸外壳 - 以及其他几个型号,xxxx代表连接器类型。
器件简介: - 这些天线系统提供了从900MHz到5850MHz的宽频带操作选项,具有极好的系统灵活性。 - 外壳采用压铸铝制成,天线系统可独立使用或与低增益天线或高增益面板天线集成。
引脚分配: - 文档中未提供具体的引脚分配信息。
参数特性: - 增益(集成天线):8dBi至19dBi - 增益(可拆卸天线):12dBi至24dBi - 电压驻波比(VSWR):1.5:1至2:1 - 阻抗:50欧姆 - 输入功率:100W - 耐风性:压铸外壳(150mph);可拆卸天线(125mph) - 重量和尺寸:根据型号不同而有所变化
功能详解: - 提供了集成低增益或可拆卸高增益天线,具有多种频率和增益选项。 - 外壳具有11个工程化敲出孔,适用于N型连接器和电缆馈通。 - 外壳可进行杆式或壁式安装,可配合重型倾斜支架使用。
应用信息: - 适用于WiFi/WLAN/WiMAX系统、工业无线、网状网络、Wi-POP基站、客户端天线和工业湿法电气外壳。
封装信息: - 外壳材料为UV抗性ASA塑料,硬件为不锈钢。 - 天线系统带有尾缆和多种连接器选项。 - 内部有可移除和定制的用户安装板,用于安装电子设备。
DCE10I-2416-RTNM 价格&库存
很抱歉,暂时无法提供与“DCE10I-2416-RTNM”相匹配的价格&库存,您可以联系我们找货
